Hey, I installed brickd  using Raspberry 3 & 4 without problems. Now I use a Raspberry 5 (64bit) and got some errors during installation for the software. Which I solved using:
  1. sudo apt-get install libusb-1.0-0 libudev1 procps
  2. wget https://download.tinkerforge.com/apt/$(. /etc/os-release; echo $ID)/tinkerforge.asc -q -O - | sudo tee /etc/apt/trusted.gpg.d/tinkerforge.asc > /dev/null
  3. echo "deb https://download.tinkerforge.com/apt/$(. /etc/os-release; echo $ID $VERSION_CODENAME) main" | sudo tee /etc/apt/sources.list.d/tinkerforge.list
  4. sudo apt update
  5. sudo apt install brickd
This results in an error, which can be solved by:  sudo apt --fix-broken install
The installation shows no further errors, but the brickd is not running. In the Logfile is written:
    2024-05-25 16:18:54.556720 <I> <main_linux.c:369> Brick Daemon 2.4.5 started (pid: 2954, daemonized: 1)
    2024-05-25 16:18:54.556735 <I> <main_linux.c:375> Running on Linux system (sysname: Linux, release: 6.6.20+rpt-rpi-2712, version: #1 SMP PREEMPT Debian 1:6.6.20-1+rpt1 (2024-03-07),                  machine: aarch64) libusb: warning [libusb_init] installing new context as implicit default
    2024-05-25 16:18:54.561928 <I> <bricklet.c:304> Found supported HAT product_id 0x085d in device tree, using default HAT Zero Brick config
    2024-05-25 16:18:54.561936 <I> <bricklet.c:345> Found Bricklet port A (spidev: /dev/spidev0.0, driver: gpio, name: gpio426, num: 426)
    2024-05-25 16:18:54.561957 <I> <bricklet_stack_linux.c:87> Using spidev backend for Bricklets (unsupported suffix 5 after 'Raspberry Pi' in /proc/device-tree/model)
    2024-05-25 16:18:54.561994 <E> <gpio_sysfs.c:77> Could not write to '/sys/class/gpio/export' to export GPIO 426: EINVAL (22)
    2024-05-25 16:18:54.561997 <E> <bricklet_stack_linux_spidev.c:78> Could not export gpio426: EINVAL (22)
    2024-05-25 16:18:54.562163 <I> <main_linux.c:563> Brick Daemon 2.4.5 stopped
I already flashed the hardware to the newest version.n error occur
Any idea what is wrong?
I cannot reproduce the "sudo apt --fix-broken install" here.
Where did you find that you should install the dependencies (sudo apt-get install libusb-1.0-0 libudev1 procps) by hand? This is not neccessary. Also libudev1 is not required anymore. There where a few places left that still mentioned libudev1, I updated them now.
Please try this brickd version, this should fix the GPIO problem.
Edit: Attachment deleted. Brick Daemon 2.4.6 has been released. Please install the official release instead.
Thanks for your feedback.
To answer the question, where I found the installation information. I followed the recommendation under:
     https://www.tinkerforge.com/en/doc/Software/Brickd.html
I choose under "Installation" Linux
     https://www.tinkerforge.com/en/doc/Software/Brickd_Install_Linux.html#brickd-install-linux
Then under "APT Repository" I found First, set up our APT repository on your system according to this guide
     https://www.tinkerforge.com/en/doc/Software/APT_Repository.html#apt-repository
To solve the problem, first I reinstalled a new blank version for the Raspberry 5/64bit.  The I used your .deb-file with the command:
     sudo apt install ./brickd_2.4.6+snapshot~730b7d7_arm64.deb
It worked I only got an error at the end, here the result:
     N: Download is performed unsandboxed as root as file '/media/pi/SCAN/_Tinkerbell/Scripts/RaspBerry BaseInstall Tinker/brickd_2.4.6+snapshot~730b7d7_arm64.deb' couldn't be                  accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
The file /media/pi/SCAN/_Tinkerbell/Scripts/RaspBerry BaseInstall Tinker/brickd_2.4.6+snapshot~730b7d7_arm64.deb' has the rights: -rwxr-xr-x
But the demon is running and brickv can connect.
Thanks for the help
  • 4 weeks later...
Hi JonD
Have you been successful in the meantime to install and using brickv?
I have probably the same error.
Cheers,
Yvo
Dear photron
Great, I just updated brickd using the update-tool of the Raspberry and it works.
Thank you very much for all your work.
Cheers,
Yvo
