Linux compatibility (CentOS)
I just tried to install the brick daemon on my CentOS 5.8 system. Unfortunately I met with many problems.
I can't find a gudev-python rpm for it (why does a daemon need a desktop library anyway?)
I can't find an rpm for the libusb that is required, just something called 'libusb'.
At least the python-twisted stuff is there (by default).
When I try to run the daemon anyway I get:
./brickd_linux.py
  File "./brickd_linux.py", line 30, in ?
    from usb_notifier import USBNotifier
  File "/usr/src/Tinkerforge-brickd-1836e39/src/brickd/usb_notifier.py", line 30
    class USBNotifier():
It would be nice if you could offer a little bit wider distribution support than just Debian. CentOS/RHEL/Fedora Core are widely used.
Has anyone tackled this problem before?
python-gudev is needed for USB hotplug, you can use brickd without it (you have to plug in the Bricks before starting brickd in that case).
Regarding your traceback: Is that the complete traceback? It isn't saying anything.
Can you change the logging level to logging.DEBUG in config.py and then run brickd with ./brickd_linux nodaemon and post the outcome?
edit: I just did a quick search, it seems libusb1 and python-gudev is readily available as rpm:
http://rpm.pbone.net/index.php3/stat/3/srodzaj/1/search/libusb1
http://rpm.pbone.net/index.php3/stat/3/srodzaj/1/search/python-gudev
there are also rpm's for CentOS 6 in the list (i can't see any for 5.8 unfortunately).
I could do without the hotplug so that's no problem.
Done that, changed the config.py in the brickd/src directory, same result:
# ./brickd_linux.py nodaemon
SyntaxError: invalid syntax
My Python knowledge is virtually non existent.
Perhaps the CentOS python version is not supported? Info:
Python 2.4.3 (#1, Feb 22 2012, 16:06:13)
[GCC 4.1.2 20080704 (Red Hat 4.1.2-52)] on linux2
Or perhaps I just don't have the right USB library installed...?
No idea what is going on there. There is no way to install python 2.4 on any of the systems i have here (other then compiling it from source), but there is nothing that could be considered a syntax error in any python version at that location.
I'll try installing one of those libusb1 rpm's, I'll report back if I get it to work.
I guess it wouldn't be a big problem to upgrade to CentOS 6, which apparently comes with Python 2.6 if I can't get it to work otherwise.
Update:
- I couldn't install libusb1 from these rpms
- Instead I installed Virtualbox on a Windows machine
- I loaded up the Centos 6.2 image from here: http://virtualboxes.org/images/centos/
- Installed the USB drivers for Virtualbox
- Changed networking to bridged
- Added the Master Brick to the USB filters
And then it all went smoothly:
- yum update
- libusb1 was already installed
- yum install python-twisted
- yum install python-gudev
- ./brickd_linux.py
I was able to run brickv on the windows box and control my bricks via the brickd on the centos 6.2 VM.
So it seems upgrading my server to CentOS 6.2 would seem the way to go... (it's good to know this in advance that it's going to work before going through all the hassle of upgrading my server)
Install Virtualbox and mount the Centos 5.8 image on http://virtualboxes.org/images/centos/ . You'll be up in 5 minutes. Many other system images available. Great for testing!
I upgraded to CentOS 6.2 and (most) everything is working fine (except from my RAID5 setup that suddenly developed a split personality, but that's for a different forum.
Brickd is humming away nicely. I would appreciate an RPM eventually, though, to make things 'official'.
CentOS 5.x works as well, but python24 is not ideal, there are some additional dependencies, such as ctypes.
I added python26(std repo) and installed twisted and libusb1 from source. brickd runs fine on CentOS 5.
