openhab Integration
so jetzt der Post bis Fehler.
2016-11-10 17:33:26.371 [iNFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.3).
2016-11-10 17:33:30.818 [iNFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2016-11-10 17:33:31.267 [iNFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2016-11-10 17:33:31.282 [iNFO ] [.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2016-11-10 17:33:31.286 [iNFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2016-11-10 17:33:39.306 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2016-11-10 17:33:39.882 [iNFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2016-11-10 17:33:40.480 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'handy.sitemap'
2016-11-10 17:33:40.520 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'mysensors.sitemap'
2016-11-10 17:33:40.557 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'diagramme.sitemap'
2016-11-10 17:33:40.683 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'db4o.persist'
2016-11-10 17:33:40.767 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2016-11-10 17:33:40.781 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'logging.persist'
2016-11-10 17:33:40.816 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'exec.persist'
2016-11-10 17:33:40.881 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'milight.items'
2016-11-10 17:33:41.037 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'tinkerforge.items'
2016-11-10 17:33:41.063 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'lichtschalter.items'
2016-11-10 17:33:41.129 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'steuerungen_an_aus.items'
2016-11-10 17:33:41.161 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'pioneer.items'
2016-11-10 17:33:41.202 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'harmony.items'
2016-11-10 17:33:41.236 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'systeminfos.items'
2016-11-10 17:33:41.310 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'hue_rgb.items'
2016-11-10 17:33:41.347 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'homematic_temperatur.items'
2016-11-10 17:33:41.431 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'aquarium.items'
2016-11-10 17:33:41.601 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'fritz.box.items'
2016-11-10 17:33:41.645 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'steckdosen.items'
2016-11-10 17:33:41.711 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'lacross_sensoren.items'
2016-11-10 17:33:41.765 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'fensterkontakte.items'
2016-11-10 17:33:41.809 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'homematic.items'
2016-11-10 17:33:41.860 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'batterie_spannung.items'
2016-11-10 17:33:41.908 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'mqtt.items'
2016-11-10 17:33:41.951 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'astro.items'
2016-11-10 17:33:42.046 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'garten_terrasse.items'
2016-11-10 17:33:42.094 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'haus.items'
2016-11-10 17:33:42.158 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'bewaesserung.items'
2016-11-10 17:33:42.216 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'heizungen.items'
2016-11-10 17:33:42.300 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'batterie_status.items'
2016-11-10 17:33:45.656 [iNFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /classicui/openhab.app
2016-11-10 17:33:52.575 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'haus.rules'
2016-11-10 17:33:53.962 [iNFO ] [o.harmonyhub.HarmonyHubGateway] - HarmonyHub gateway activated
2016-11-10 17:33:54.335 [iNFO ] [o.o.b.h.i.bus.HomematicBinding] - HomematicConfig[host=192.168.178.32,timeout=15,callbackHost=192.168.178.53,callbackPort=9123,aliveInterval=300,reconnectInterval=disabled]
2016-11-10 17:33:54.337 [iNFO ] [.b.h.i.c.HomematicCommunicator] - Starting Homematic communicator
2016-11-10 17:33:54.418 [iNFO ] [.b.h.i.c.HomematicCommunicator] - Homematic ServerId[name=CCU,version=2.19.9,address=KEQ1064931]
2016-11-10 17:33:54.437 [iNFO ] [o.o.b.h.i.c.client.CcuClient  ] - Starting CcuClient
2016-11-10 17:33:54.587 [iNFO ] [b.h.i.communicator.StateHolder] - Loading Homematic datapoints
2016-11-10 17:33:58.303 [iNFO ] [.p.rrd4j.internal.RRD4jService] - Removing invalid defintion component = null heartbeat = 0 min/max = 0.0/0.0 step = 0 0 archives(s) = [] 0 items(s) = []
2016-11-10 17:34:03.839 [iNFO ] [.service.AbstractActiveService] - HTTP Refresh Service has been started
2016-11-10 17:34:04.032 [iNFO ] [.service.AbstractActiveService] - Exec Refresh Service has been started
2016-11-10 17:34:04.503 [WARN ] [inding.hue.internal.HueBinding] - Hue binding skipped command because no Hue bridge is connected.
2016-11-10 17:34:07.464 [iNFO ] [.service.AbstractActiveService] - FritzboxTr064 Refresh Service has been started
2016-11-10 17:34:07.490 [iNFO ] [o.o.b.f.i.FritzboxTr064Binding] - Downloading phonebook ID 0
2016-11-10 17:34:10.052 [iNFO ] [o.o.b.f.i.FritzboxTr064Binding] - Callmonitor Thread [127] attempting connection to FritzBox on 192.168.178.1:1012..
2016-11-10 17:34:10.055 [iNFO ] [o.o.b.f.i.FritzboxTr064Binding] - Connected to FritzBox on 192.168.178.1:1012
2016-11-10 17:34:11.022 [iNFO ] [b.h.i.communicator.StateHolder] - Finished loading 2186 Homematic datapoints
2016-11-10 17:34:11.023 [iNFO ] [b.h.i.communicator.StateHolder] - Loading Homematic Server variables
2016-11-10 17:34:11.083 [iNFO ] [b.h.i.communicator.StateHolder] - Finished loading 5 Homematic server variables
2016-11-10 17:34:11.084 [iNFO ] [b.h.i.c.s.BinRpcCallbackServer] - Starting BinRpcCallbackServer at port 9123
2016-11-10 17:34:12.310 [iNFO ] [.o.b.h.i.c.client.BinRpcClient] - Interface BidCos-Wired not available, disabling support.
2016-11-10 17:34:12.313 [iNFO ] [.o.b.h.i.c.client.BinRpcClient] - Interface CUxD not available, disabling support.
2016-11-10 17:34:12.314 [iNFO ] [.b.h.i.c.HomematicCommunicator] - Scheduling one datapoint reload job in one minute
2016-11-10 17:34:12.317 [iNFO ] [.service.AbstractActiveService] - Homematic server connection tracker has been started
2016-11-10 17:34:13.112 [iNFO ] [nding.lacrosse.LaCrosseBinding] - Update LaCrosse Binding ...
2016-11-10 17:34:13.167 [ERROR] [b.t.i.m.impl.RemoteSwitchAImpl] - TFINITSUB missing configuration for subid rslr1 device will not work
2016-11-10 17:34:13.112 [iNFO ] [.service.AbstractActiveService] - Tinkerforge Refresh Service has been started
2016-11-10 17:34:14.544 [ERROR] [.i.MBrickletAmbientLightV2Impl] - invalid illuminanceRange value: 3
2016-11-10 17:34:16.071 [iNFO ] [.l.connector.LaCrosseConnector] - Open LaCrosse connection
2016-11-10 17:34:22.772 [iNFO ] [b.s.internal.SysteminfoBinding] - Using Sigar version 1.6.4.129
2016-11-10 17:34:22.781 [iNFO ] [.service.AbstractActiveService] - Systeminfo Refresh Service has been started
2016-11-10 17:34:22.793 [iNFO ] [.b.a.internal.bus.AstroBinding] - AstroConfig[latitude=49.387218,longitude=8.37472,interval=60,systemTimezone=Europe/Berlin (CET +0100),daylightSavings=false]
2016-11-10 17:34:22.799 [iNFO ] [.z.internal.ZWaveActiveBinding] - ZWave 'updated' with null config
2016-11-10 17:34:22.799 [iNFO ] [.service.AbstractActiveService] - FritzAHA Refresh Service has been started
2016-11-10 17:34:25.595 [iNFO ] [.l.connector.LaCrosseConnector] - -17.6 -> 106
2016-11-10 17:34:25.804 [iNFO ] [.b.a.internal.job.JobScheduler] - Scheduled a daily job at midnight for astro calculation
2016-11-10 17:34:25.807 [ERROR] [o.o.b.p.i.i.IpControl         ] - Can't connect 192.168.178.27:8102: No route to host
2016-11-10 17:34:25.809 [iNFO ] [.b.a.internal.job.JobScheduler] - Scheduled astro job with interval of 60 seconds
2016-11-10 17:34:40.806 [ERROR] [o.o.b.p.i.i.IpControl         ] - Can't connect 192.168.178.27:8102: No route to host
2016-11-10 17:34:40.916 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 4
2016-11-10 17:34:40.917 [iNFO ] [.l.connector.LaCrosseConnector] - 21.5 -> 53
2016-11-10 17:34:41.454 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 13
2016-11-10 17:34:41.455 [iNFO ] [.l.connector.LaCrosseConnector] - 16.8 -> 63
2016-11-10 17:34:42.437 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 27
2016-11-10 17:34:42.439 [iNFO ] [.l.connector.LaCrosseConnector] - -17.7 -> 106
2016-11-10 17:34:42.722 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 8
2016-11-10 17:34:42.724 [iNFO ] [.l.connector.LaCrosseConnector] - 22.4 -> 70
2016-11-10 17:34:43.079 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 45
2016-11-10 17:34:43.081 [iNFO ] [.l.connector.LaCrosseConnector] - 5.3 -> 106
2016-11-10 17:34:43.327 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 47
2016-11-10 17:34:43.329 [iNFO ] [.l.connector.LaCrosseConnector] - 20.4 -> 60
2016-11-10 17:34:43.789 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 38
2016-11-10 17:34:43.791 [iNFO ] [.l.connector.LaCrosseConnector] - 19.8 -> 58
2016-11-10 17:34:43.806 [ERROR] [o.o.b.p.i.i.IpControl         ] - Can't connect 192.168.178.27:8102: No route to host
2016-11-10 17:34:45.170 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 21
2016-11-10 17:34:45.172 [iNFO ] [.l.connector.LaCrosseConnector] - 19.6 -> 59
2016-11-10 17:34:45.555 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 13
2016-11-10 17:34:45.556 [iNFO ] [.l.connector.LaCrosseConnector] - 16.8 -> 63
2016-11-10 17:34:46.072 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 15
2016-11-10 17:34:46.073 [iNFO ] [.l.connector.LaCrosseConnector] - 17.5 -> 61
2016-11-10 17:34:46.649 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 27
2016-11-10 17:34:46.658 [iNFO ] [.l.connector.LaCrosseConnector] - -17.7 -> 106
2016-11-10 17:34:46.806 [ERROR] [o.o.b.p.i.i.IpControl         ] - Can't connect 192.168.178.27:8102: No route to host
2016-11-10 17:34:46.808 [iNFO ] [.service.AbstractActiveService] - NTP Refresh Service has been started
2016-11-10 17:34:46.809 [iNFO ] [.service.AbstractActiveService] - NetworkHealth Refresh Service has been started
2016-11-10 17:35:14.574 [ERROR] [.service.AbstractActiveService] - Error while executing background thread Tinkerforge Refresh Service
java.lang.NullPointerException: null
at org.openhab.binding.tinkerforge.internal.model.impl.MBrickletAmbientLightV2Impl.fetchSensorValue(MBrickletAmbientLightV2Impl.java:879) ~[na:na]
at org.openhab.binding.tinkerforge.internal.TinkerforgeBinding.updateItemValues(TinkerforgeBinding.java:645) ~[na:na]
at org.openhab.binding.tinkerforge.internal.TinkerforgeBinding.execute(TinkerforgeBinding.java:608) ~[na:na]
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:156) ~[na:na]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173) ~[na:na]
ich habe nur einige Temperatureintragungen von den lacross Sensoren gelöscht.
  • Replies 526
  • Aufrufe 370,3k
Ich sehe zwei Fehler, die TF betreffen (erkennbar am ERROR im Log):
und ein weiterer, der nichts mit diesem Problem hier zu tun hat:
Kannst du mal illuminanceRange aus der config rausnehmen und sehen, ob es dann funktioniert.
Ich habe die Zeile gelöscht und im Log kommt der Fehler
oder muss ich noch Openhab neu starten?
Bitte neu starten.
Habe neu gestartet
2016-11-11 18:47:03.323 [iNFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.3).
2016-11-11 18:47:23.054 [iNFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2016-11-11 18:47:23.218 [iNFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2016-11-11 18:47:23.511 [iNFO ] [.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2016-11-11 18:47:23.513 [iNFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2016-11-11 18:47:31.557 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2016-11-11 18:47:32.112 [iNFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2016-11-11 18:47:32.739 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'handy.sitemap'
2016-11-11 18:47:32.778 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'mysensors.sitemap'
2016-11-11 18:47:32.811 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'diagramme.sitemap'
2016-11-11 18:47:32.935 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'db4o.persist'
2016-11-11 18:47:33.016 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2016-11-11 18:47:33.031 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'logging.persist'
2016-11-11 18:47:33.067 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'exec.persist'
2016-11-11 18:47:33.131 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'milight.items'
2016-11-11 18:47:33.287 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'tinkerforge.items'
2016-11-11 18:47:33.314 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'lichtschalter.items'
2016-11-11 18:47:33.424 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'steuerungen_an_aus.items'
2016-11-11 18:47:33.456 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'pioneer.items'
2016-11-11 18:47:33.496 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'harmony.items'
2016-11-11 18:47:33.531 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'systeminfos.items'
2016-11-11 18:47:33.601 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'hue_rgb.items'
2016-11-11 18:47:33.638 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'homematic_temperatur.items'
2016-11-11 18:47:33.673 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'aquarium.items'
2016-11-11 18:47:33.703 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'fritz.box.items'
2016-11-11 18:47:33.747 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'steckdosen.items'
2016-11-11 18:47:33.812 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'lacross_sensoren.items'
2016-11-11 18:47:33.865 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'fensterkontakte.items'
2016-11-11 18:47:33.907 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'homematic.items'
2016-11-11 18:47:33.987 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'batterie_spannung.items'
2016-11-11 18:47:34.032 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'mqtt.items'
2016-11-11 18:47:34.072 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'astro.items'
2016-11-11 18:47:34.135 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'garten_terrasse.items'
2016-11-11 18:47:34.180 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'haus.items'
2016-11-11 18:47:34.246 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'bewaesserung.items'
2016-11-11 18:47:34.321 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'heizungen.items'
2016-11-11 18:47:34.407 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'batterie_status.items'
2016-11-11 18:47:38.129 [iNFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /classicui/openhab.app
2016-11-11 18:47:44.688 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'haus.rules'
2016-11-11 18:47:46.698 [iNFO ] [o.harmonyhub.HarmonyHubGateway] - HarmonyHub gateway activated
2016-11-11 18:47:47.531 [iNFO ] [o.o.b.h.i.bus.HomematicBinding] - HomematicConfig[host=192.168.178.32,timeout=15,callbackHost=192.168.178.53,callbackPort=9123,aliveInterval=300,reconnectInterval=disabled]
2016-11-11 18:47:47.532 [iNFO ] [.b.h.i.c.HomematicCommunicator] - Starting Homematic communicator
2016-11-11 18:47:47.593 [iNFO ] [.b.h.i.c.HomematicCommunicator] - Homematic ServerId[name=CCU,version=2.19.9,address=KEQ1064931]
2016-11-11 18:47:47.615 [iNFO ] [o.o.b.h.i.c.client.CcuClient  ] - Starting CcuClient
2016-11-11 18:47:47.771 [iNFO ] [b.h.i.communicator.StateHolder] - Loading Homematic datapoints
2016-11-11 18:47:50.890 [iNFO ] [.service.AbstractActiveService] - FritzboxTr064 Refresh Service has been started
2016-11-11 18:47:50.899 [iNFO ] [o.o.b.f.i.FritzboxTr064Binding] - Downloading phonebook ID 0
2016-11-11 18:47:50.976 [iNFO ] [.service.AbstractActiveService] - HTTP Refresh Service has been started
2016-11-11 18:47:52.290 [iNFO ] [.service.AbstractActiveService] - Exec Refresh Service has been started
2016-11-11 18:47:52.903 [iNFO ] [o.o.b.f.i.FritzboxTr064Binding] - Callmonitor Thread [105] attempting connection to FritzBox on 192.168.178.1:1012..
2016-11-11 18:47:52.906 [iNFO ] [o.o.b.f.i.FritzboxTr064Binding] - Connected to FritzBox on 192.168.178.1:1012
2016-11-11 18:47:54.849 [iNFO ] [.p.rrd4j.internal.RRD4jService] - Removing invalid defintion component = null heartbeat = 0 min/max = 0.0/0.0 step = 0 0 archives(s) = [] 0 items(s) = []
2016-11-11 18:48:00.716 [WARN ] [inding.hue.internal.HueBinding] - Hue binding skipped command because no Hue bridge is connected.
2016-11-11 18:48:04.538 [iNFO ] [b.h.i.communicator.StateHolder] - Finished loading 2186 Homematic datapoints
2016-11-11 18:48:04.539 [iNFO ] [b.h.i.communicator.StateHolder] - Loading Homematic Server variables
2016-11-11 18:48:04.591 [iNFO ] [b.h.i.communicator.StateHolder] - Finished loading 5 Homematic server variables
2016-11-11 18:48:04.592 [iNFO ] [b.h.i.c.s.BinRpcCallbackServer] - Starting BinRpcCallbackServer at port 9123
2016-11-11 18:48:10.011 [iNFO ] [.o.b.h.i.c.client.BinRpcClient] - Interface BidCos-Wired not available, disabling support.
2016-11-11 18:48:10.014 [iNFO ] [.o.b.h.i.c.client.BinRpcClient] - Interface CUxD not available, disabling support.
2016-11-11 18:48:10.015 [iNFO ] [.b.h.i.c.HomematicCommunicator] - Scheduling one datapoint reload job in one minute
2016-11-11 18:48:10.020 [iNFO ] [.service.AbstractActiveService] - Homematic server connection tracker has been started
2016-11-11 18:48:10.883 [iNFO ] [nding.lacrosse.LaCrosseBinding] - Update LaCrosse Binding ...
2016-11-11 18:48:10.883 [iNFO ] [.service.AbstractActiveService] - Tinkerforge Refresh Service has been started
2016-11-11 18:48:10.939 [ERROR] [b.t.i.m.impl.RemoteSwitchAImpl] - TFINITSUB missing configuration for subid rslr1 device will not work
2016-11-11 18:48:10.943 [ERROR] [.i.MBrickletAmbientLightV2Impl] - invalid integrationTime value: 3
2016-11-11 18:48:11.000 [iNFO ] [.l.connector.LaCrosseConnector] - Open LaCrosse connection
2016-11-11 18:48:11.396 [iNFO ] [b.s.internal.SysteminfoBinding] - Using Sigar version 1.6.4.129
2016-11-11 18:48:11.406 [iNFO ] [.z.internal.ZWaveActiveBinding] - ZWave 'updated' with null config
2016-11-11 18:48:11.406 [iNFO ] [.service.AbstractActiveService] - Systeminfo Refresh Service has been started
2016-11-11 18:48:13.433 [iNFO ] [.service.AbstractActiveService] - NetworkHealth Refresh Service has been started
2016-11-11 18:48:13.448 [iNFO ] [.service.AbstractActiveService] - FritzAHA Refresh Service has been started
2016-11-11 18:48:13.463 [iNFO ] [.service.AbstractActiveService] - NTP Refresh Service has been started
2016-11-11 18:48:13.555 [iNFO ] [.b.a.internal.bus.AstroBinding] - AstroConfig[latitude=49.387218,longitude=8.37472,interval=60,systemTimezone=Europe/Berlin (CET +0100),daylightSavings=false]
2016-11-11 18:49:10.929 [ERROR] [.service.AbstractActiveService] - Error while executing background thread Tinkerforge Refresh Service
Nimm auch die integrationTime aus deiner Konfiguration raus und starte neu.
Sehr gut!
Da werde ich wohl noch einen Fix für illuminanceRange und integrationTime schreiben müssen. Ich gebe Bescheid sobald es was zum Testen gibt.
Was ist den illuminanceRange und integrationTime was kann man damit machen.
Hallo Theo,
ich habe auch noch ein Moisture und UV Bricklet mit einem Master und WIFI Master Extension 2.0 versucht in mein Openhab zu bekommenes funktioniert nicht. Aus dem Wiki habe ich die Konfiguration kopiert und die uid geändert.
Wenn ich Openhab neu starte, sehe ich im LOG nichts von Tinkerforge es gehen auch nicht mehr die Hardware die schon funktioniert hat. Ich müste doch  Tinkerforge Refresh Service has been starte sehen im LOG das finde ich aber nicht und es geht nichts mehr ich finde auch kein Error !
Was ist den da los ?
Bitte poste den kompletten Log und deine openhab.cfg.
Der LOG
2016-11-19 21:28:21.967 [iNFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.3).
2016-11-19 21:28:26.463 [iNFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2016-11-19 21:28:26.894 [iNFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2016-11-19 21:28:26.907 [iNFO ] [.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2016-11-19 21:28:26.909 [iNFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2016-11-19 21:28:34.979 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2016-11-19 21:28:35.673 [iNFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2016-11-19 21:28:36.168 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'handy.sitemap'
2016-11-19 21:28:36.208 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'desktop.sitemap'
2016-11-19 21:28:36.539 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'db4o.persist'
2016-11-19 21:28:36.630 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2016-11-19 21:28:36.647 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'logging.persist'
2016-11-19 21:28:36.675 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'exec.persist'
2016-11-19 21:28:36.744 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'milight.items'
2016-11-19 21:28:36.889 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'tinkerforge.items'
2016-11-19 21:28:36.921 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'lichtschalter.items'
2016-11-19 21:28:37.039 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'steuerungen_an_aus.items'
2016-11-19 21:28:37.069 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'pioneer.items'
2016-11-19 21:28:37.108 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'harmony.items'
2016-11-19 21:28:37.141 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'systeminfos.items'
2016-11-19 21:28:37.185 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'hue_rgb.items'
2016-11-19 21:28:37.243 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'homematic_temperatur.items'
2016-11-19 21:28:37.278 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'aquarium.items'
2016-11-19 21:28:37.316 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'fritz.box.items'
2016-11-19 21:28:37.361 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'steckdosen.items'
2016-11-19 21:28:37.421 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'lacross_sensoren.items'
2016-11-19 21:28:37.472 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'fensterkontakte.items'
2016-11-19 21:28:37.516 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'homematic.items'
2016-11-19 21:28:37.603 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'batterie_spannung.items'
2016-11-19 21:28:37.653 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'mqtt.items'
2016-11-19 21:28:37.690 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'astro.items'
2016-11-19 21:28:37.755 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'garten_terrasse.items'
2016-11-19 21:28:37.804 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'haus.items'
2016-11-19 21:28:37.873 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'bewaesserung.items'
2016-11-19 21:28:37.952 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'heizungen.items'
2016-11-19 21:28:38.035 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'batterie_status.items'
2016-11-19 21:28:41.511 [iNFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /classicui/openhab.app
2016-11-19 21:28:47.581 [iNFO ] [o.harmonyhub.HarmonyHubGateway] - HarmonyHub gateway activated
2016-11-19 21:28:47.940 [iNFO ] [o.o.b.h.i.bus.HomematicBinding] - HomematicConfig[host=192.168.178.32,timeout=15,callbackHost=192.168.178.53,callbackPort=9123,aliveInterval=300,reconnectInterval=disabled]
2016-11-19 21:28:47.944 [iNFO ] [.b.h.i.c.HomematicCommunicator] - Starting Homematic communicator
2016-11-19 21:28:48.004 [iNFO ] [.b.h.i.c.HomematicCommunicator] - Homematic ServerId[name=CCU,version=2.19.9,address=LEQ1005763]
2016-11-19 21:28:48.031 [iNFO ] [o.o.b.h.i.c.client.CcuClient  ] - Starting CcuClient
2016-11-19 21:28:48.195 [iNFO ] [b.h.i.communicator.StateHolder] - Loading Homematic datapoints
2016-11-19 21:28:48.279 [iNFO ] [c.internal.ModelRepositoryImpl] - Loading model 'haus.rules'
2016-11-19 21:28:50.990 [ERROR] [o.harmonyhub.HarmonyHubGateway] - Failed creating harmony hub connection to 192.168.178.33
java.lang.RuntimeException: Failed to parse response from Logitech auth service
at net.whistlingfish.harmony.protocol.AuthService.getLoginToken(AuthService.java:45) ~[harmony-java-client-1.0.3.jar:1.0.3]
at net.whistlingfish.harmony.HarmonyClient.connect(HarmonyClient.java:111) ~[harmony-java-client-1.0.3.jar:1.0.3]
at org.openhab.io.harmonyhub.HarmonyHubGateway.connectClient(HarmonyHubGateway.java:193) [bundlefile:na]
at org.openhab.io.harmonyhub.HarmonyHubGateway.access$0(HarmonyHubGateway.java:189) [bundlefile:na]
at org.openhab.io.harmonyhub.HarmonyHubGateway$1.run(HarmonyHubGateway.java:176) [bundlefile:na]
at java.lang.Thread.run(Thread.java:744) [na:1.8.0]
Caused by: us.monoid.json.JSONException: JSONObject["GetUserAuthTokenResult"] is not a JSONObject.
at us.monoid.json.JSONObject.getJSONObject(JSONObject.java:579) ~[resty-0.3.2.jar:na]
at net.whistlingfish.harmony.protocol.AuthService.getLoginToken(AuthService.java:41) ~[harmony-java-client-1.0.3.jar:1.0.3]
... 5 common frames omitted
2016-11-19 21:28:52.684 [iNFO ] [.service.AbstractActiveService] - FritzboxTr064 Refresh Service has been started
2016-11-19 21:28:52.695 [iNFO ] [o.o.b.f.i.FritzboxTr064Binding] - Downloading phonebook ID 0
2016-11-19 21:28:54.323 [iNFO ] [o.o.b.f.i.FritzboxTr064Binding] - Callmonitor Thread [87] attempting connection to FritzBox on 192.168.178.1:1012..
2016-11-19 21:28:54.326 [iNFO ] [o.o.b.f.i.FritzboxTr064Binding] - Connected to FritzBox on 192.168.178.1:1012
2016-11-19 21:28:57.982 [iNFO ] [.service.AbstractActiveService] - HTTP Refresh Service has been started
2016-11-19 21:28:58.181 [iNFO ] [.p.rrd4j.internal.RRD4jService] - Removing invalid defintion component = null heartbeat = 0 min/max = 0.0/0.0 step = 0 0 archives(s) = [] 0 items(s) = []
2016-11-19 21:29:03.816 [iNFO ] [b.h.i.communicator.StateHolder] - Finished loading 2186 Homematic datapoints
2016-11-19 21:29:03.820 [iNFO ] [b.h.i.communicator.StateHolder] - Loading Homematic Server variables
2016-11-19 21:29:03.884 [iNFO ] [b.h.i.communicator.StateHolder] - Finished loading 5 Homematic server variables
2016-11-19 21:29:03.888 [iNFO ] [b.h.i.c.s.BinRpcCallbackServer] - Starting BinRpcCallbackServer at port 9123
2016-11-19 21:29:06.390 [iNFO ] [.o.b.h.i.c.client.BinRpcClient] - Interface BidCos-Wired not available, disabling support.
2016-11-19 21:29:06.396 [iNFO ] [.o.b.h.i.c.client.BinRpcClient] - Interface CUxD not available, disabling support.
2016-11-19 21:29:06.400 [iNFO ] [.b.h.i.c.HomematicCommunicator] - Scheduling one datapoint reload job in one minute
2016-11-19 21:29:06.418 [iNFO ] [.service.AbstractActiveService] - Homematic server connection tracker has been started
2016-11-19 21:29:07.346 [iNFO ] [nding.lacrosse.LaCrosseBinding] - Update LaCrosse Binding ...
2016-11-19 21:29:07.421 [iNFO ] [.l.connector.LaCrosseConnector] - Open LaCrosse connection
2016-11-19 21:29:09.441 [iNFO ] [.service.AbstractActiveService] - Exec Refresh Service has been started
2016-11-19 21:29:10.159 [iNFO ] [.z.internal.ZWaveActiveBinding] - ZWave 'updated' with null config
2016-11-19 21:29:10.186 [iNFO ] [.service.AbstractActiveService] - NetworkHealth Refresh Service has been started
2016-11-19 21:29:10.205 [iNFO ] [.service.AbstractActiveService] - NTP Refresh Service has been started
2016-11-19 21:29:10.224 [iNFO ] [.service.AbstractActiveService] - FritzAHA Refresh Service has been started
2016-11-19 21:29:10.596 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 21
2016-11-19 21:29:10.602 [iNFO ] [.l.connector.LaCrosseConnector] - 20.5 -> 60
2016-11-19 21:29:10.725 [iNFO ] [b.s.internal.SysteminfoBinding] - Using Sigar version 1.6.4.129
2016-11-19 21:29:10.755 [iNFO ] [.service.AbstractActiveService] - Systeminfo Refresh Service has been started
2016-11-19 21:29:10.769 [iNFO ] [.b.a.internal.bus.AstroBinding] - AstroConfig[latitude=49.387218,longitude=8.37472,interval=60,systemTimezone=Europe/Berlin (CET +0100),daylightSavings=false]
2016-11-19 21:29:10.955 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 4
2016-11-19 21:29:10.957 [iNFO ] [.l.connector.LaCrosseConnector] - 21.6 -> 54
2016-11-19 21:29:11.206 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 38
2016-11-19 21:29:11.208 [iNFO ] [.l.connector.LaCrosseConnector] - 19.4 -> 59
2016-11-19 21:29:12.678 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 13
2016-11-19 21:29:12.679 [iNFO ] [.l.connector.LaCrosseConnector] - 16.9 -> 65
2016-11-19 21:29:12.959 [iNFO ] [l.connector.LaCrosseConnector2] - Data for sensor 28
warum sich mein Harmony Hub auf einmal nicht mehr mit Openhab verbindet ist auch neu und ich habe keine Ahnung warum.
Die cfg
##################################Tinkerforge-Binding######################
# IP address of the Tinkerforge-Server
tinkerforge:hosts=192.168.178.28 192.168.178.78 192.168.178.29
tinkerforge:rs1.uid=v3E
tinkerforge:rs1.typeADevices=rslr1 rslr2 rslr3 rslr4 rslr5 rslr6 rslr7
tinkerforge:riff_licht_1.uid=v3E
tinkerforge:riff_licht_1.subid=rslr1
tinkerforge:riff_licht_1.type=remote_switch_a
tinkerforge:riff_licht_1.houseCode=31
tinkerforge:riff_licht_1.receiverCode=1
tinkerforge:riff_licht_2.uid=v3E
tinkerforge:riff_licht_2.subid=rslr2
tinkerforge:riff_licht_2.type=remote_switch_a
tinkerforge:riff_licht_2.houseCode=31
tinkerforge:riff_licht_2.receiverCode=2
tinkerforge:riff_licht_3.uid=v3E
tinkerforge:riff_licht_3.subid=rslr3
tinkerforge:riff_licht_3.type=remote_switch_a
tinkerforge:riff_licht_3.houseCode=31
tinkerforge:riff_licht_3.receiverCode=3
tinkerforge:riff_licht_4.uid=v3E
tinkerforge:riff_licht_4.subid=rslr4
tinkerforge:riff_licht_4.type=remote_switch_a
tinkerforge:riff_licht_4.houseCode=31
tinkerforge:riff_licht_4.receiverCode=4
tinkerforge:riff_pumpe_1.uid=v3E
tinkerforge:riff_pumpe_1.subid=rslr5
tinkerforge:riff_pumpe_1.type=remote_switch_a
tinkerforge:riff_pumpe_1.houseCode=31
tinkerforge:riff_pumpe_1.receiverCode=5
tinkerforge:riff_heizung_1.uid=v3E
tinkerforge:riff_heizung_1.subid=rslr6
tinkerforge:riff_heizung_1.type=remote_switch_a
tinkerforge:riff_heizung_1.houseCode=31
tinkerforge:riff_heizung_1.receiverCode=6
tinkerforge:riff_kuehlung_1.uid=v3E
tinkerforge:riff_kuehlung_1.subid=rslr7
tinkerforge:riff_kuehlung_1.type=remote_switch_a
tinkerforge:riff_kuehlung_1.houseCode=31
tinkerforge:riff_kuehlung_1.receiverCode=7
##################Tinkerforge Temperatur PDC########
tinkerforge:brickletptc.uid=z3d
tinkerforge:brickletptc.type=bricklet_ptc
tinkerforge:brickletptc.wiremode=2
tinkerforge:ptctemperature.uid=z3d
tinkerforge:ptctemperature.subid=ptc_temperature
tinkerforge:ptctemperature.type=ptc_temperature
tinkerforge:ptctemperature.callbackPeriod=1000
##################Tinkerforge Barometer########
tinkerforge:barometer_balcony.uid=vNi
tinkerforge:barometer_balcony.type=bricklet_barometer
tinkerforge:barometer_balcony.callbackPeriod=10000
tinkerforge:barometer_balcony.threshold=1000
##################Tinkerforge Helligkeit########
tinkerforge:ambientlightv2.uid=yEi
tinkerforge:ambientlightv2.type=bricklet_ambient_lightv2
tinkerforge:ambientlightv2.callbackPeriod=10
tinkerforge:ambientlightv2.threshold=0
##################Tinkerforge UV########
tinkerforge:uv.uid=xnq
tinkerforge:uv.type=bricklet_uv_light
tinkerforge:uv.callbackPeriod=10
tinkerforge:uv.threshold=0
##################Tinkerforge Erdfeuchte########
tinkerforge:moisture.uid=zTH
tinkerforge:moisture.type=bricklet_moisture
tinkerforge:moisture.threshold=0
tinkerforge:moisture.callbackPeriod=5000
tinkerforge:moisture.movingAverage=90
Danke für die Hilfe !
Hm, ich sehe auch kein TinkerForge mehr in deinem log. Versuch doch mal deine neuerlichen Änderungen soweit rückgängig zu machen bis du auf dem zuletzt funktionierenden Stand bist. Vielleicht kannst du damit das Problem eingrenzen.
Ich habe die Host Adresse eingetragen und Openhab gestartet funktioniert.
Und dann als erstes das UV Bricklet eingetragen und jetzt geht das gesamte Tinkerforge System nicht mehr. UV gelöscht und das Moisture Bricklet eingetragen Neustart gemacht jetzt steht im LOG wieder Tinkerforge Refresh Service has been started. Es wird mir aber noch kein Wert in Openhab angezeigt was muss ich machen damit der Wert angezeigt wird. Wenn ich wieder das UV Bricklet Eintrage geht nichts mehr.
alles hängt an einem neuen Master Brick mit WIFI Master Extension 2.0
Du legst ein Item an und lässt den Wert in der Sitemap anzeigen, Anleitung dazu hier:
https://github.com/openhab/openhab/wiki/Tinkerforge-Binding#moisture-bricklet
In deinem Falle:
Number   Moisture   "Moisture [%.1f]"  { tinkerforge="uid=zTH" }
und
Text item=Moisture
Gruß, Sigi
Edit: check auch noch einmal auf welchen Ports deine Master Bricks lauschen, man kann diese nämlich in der config angeben, etwas so:
# IP addresses / Hostnames  of the hosts running the brickd (optional port
# separated by a space, defaults to 4223)
tinkerforge:hosts=192.168.2.240:4223 192.168.2.241:4222
Hallo Sigi,
das Bodenfeuchte Bricklet funktioniert es wird mir ein Wert angezeigt nur das UV Bricklet bringt das ganze Tinkerforge System durcheinander.
Gruss Michael
Deshalb meine Frage nach der Port Nummer ... Da du schreibst du hast ein neues Master Brick dafür installiert könnte es ja sein es lauscht auf dem gleichen Port.
Gruß, Sigi
Edit: eine gute Hilfe einen Fehler zu finden ist immer der Brick Viewer: erst einmal schauen ob man dort etwas angezeigt bekommt, wenn ja, dann erst versuchen das Ganze an openHAB anzubinden
hatte die 1.8.3 mit der 1.9.0 geht es Oh man !
Hallo Theo
Ich versuche gerade mit Openhab2 wenn ich das Binding in der Paper UI installiert habe und die gleichen Eintragungen in der cfg wie bei Openhab1 gemacht habe neugestartet habe ich auch, wie muss ich die item ändern ? es funktioniert noch nicht.
Gar nicht. Es handelt sich um ein 1.9 Binding, alles bleibt wie es war.
Allerdings musst du die Konfiguration aus der openhab.cfg in die tinkerforge.cfg übertragen und das vorangestellte "tinkerforge:" löschen.
Näheres dazu hier:
http://docs.openhab.org/tutorials/migration#configure-add-ons
Edit: der Link springt nicht an die exakte Stelle wo das beschrieben ist, ein Auszug also hier:
Once a binding or add-on is installed, it will create a <openHAB 2 conf>/services/<add-on name>.cfg file. Unlike in openHAB 1.x where all the binding configurations are placed in the one openhab.cfg file, openHAB 2 has a separate .cfg file for each binding. Transfer the settings for each binding from openhab.cfg to its new .cfg file, removing the binding name from the parameter. For example, the parameter nest:refresh=300000 in openhab.cfg becomes refresh=300000 in nest.cfg.
Die cfg habe ich kopiert und auch tinkerforge: gelöscht neustart gemacht geht aber nicht
Tja, dann geht es wieder von vorne los: was sagt dein debug log?
Um noch einmal auf die vorherigen Posts zurückzukommen:
Lief denn inzwischen alles in openHAB1?
Falls nein, hast du den Brick Viewer genutzt um die Tinkerforge Hardware zu überprüfen?
Am Rande sei ergänzt: meine Erfahrung mit Tinkerforge war sowohl in openHAB1 als auch in openHAB2 sehr positiv, in beiden Versionen lief alles wie am Schnürchen und stabil.
Das werden wir dann bei dir auch noch hinbekommen  :)
Gruß, Sigi
das funktioniert alles in Openhab1 und im Brick Viewer auch. Das LOG muss ich mir noch mal anschauen.
