Segment Display 4x7: API request
void setCounterValue(short value); // value 0..9999
Would be really nice. Any plans on adding this?
(just trying to make a simple little clock)
Without the API, you need to jump through a few hoops to manage the segments yourself..
package com.softwarepearls.apps.hardware.tinkerforge.clock.sevensegment;
import static com.softwarepearls.lego.hardware.tinkerforge.enums.BrickletType.BRICKLET_SEGMENT_DISPLAY_4x7;
import com.softwarepearls.lego.graphics.SevenSegmentDigits;
import com.softwarepearls.lego.hardware.tinkerforge.interfaces.io.SegmentDisplay4x7;
import com.softwarepearls.lego.hardware.tinkerforge.stack.BrickletDescriptor;
import com.softwarepearls.lego.hardware.tinkerforge.stack.TinkerForgeStack;
import com.softwarepearls.lego.time.Frequency;
import com.softwarepearls.lego.time.TimeAndDateKit;
import com.tinkerforge.TinkerforgeException;
import java.io.IOException;
import java.text.DateFormat;
import java.text.SimpleDateFormat;
import java.util.Arrays;
import java.util.Date;
import java.util.List;
* Bare-bones 24 hour HH:MM clock rendered on a Tinkerforge 7-segment display.
public final class Clock {
private static final int NUM_DIGITS = 4;
private static final String DISPLAY_UID = "kTz";
private static final String TO_TF_SEGMENTS_LUT = "AFBGECD";
private final static DateFormat DATE_FORMATTER = new SimpleDateFormat("HHmm");
private static final List<BrickletDescriptor> EXPECTED_BRICKLETS = Arrays.asList(
		new BrickletDescriptor(BRICKLET_SEGMENT_DISPLAY_4x7, DISPLAY_UID));
private static void go() throws TinkerforgeException, IOException {
	final TinkerForgeStack tinkerForgeStack = TinkerForgeStack.initializeTinkerForgeStack(EXPECTED_BRICKLETS);
	final SegmentDisplay4x7 display = (SegmentDisplay4x7) tinkerForgeStack.getBricklet(DISPLAY_UID);
	final Frequency clockRefreshFrequency = Frequency.EVERY_SECOND;
	while (true) {
		final int hhmmDigits = timeDigitsFor(new Date());
		final short[] segments = getSegmentBitsFor(hhmmDigits);
		final boolean flashingColon = (TimeAndDateKit.currentSecond() & 1) == 0;
		display.setSegments(segments, (short) 2, flashingColon);
		clockRefreshFrequency.delay();
private static int timeDigitsFor(final Date time) {
	final String timeString = DATE_FORMATTER.format(time);
	return Integer.parseInt(timeString);
private static short[] getSegmentBitsFor(final int value) {
	if ((value < 0) || (value > 9999)) {
		throw new IllegalArgumentException("Illegal value for 7-segment display: " + value);
	final short[] segments = new short[NUM_DIGITS];
	int dddd = value;
	for (int i = 0; i < NUM_DIGITS; i++) {
		segments[NUM_DIGITS - 1 - i] = segmentBitsForDigit(dddd);
		dddd = dddd / 10;
	return segments;
private static short segmentBitsForDigit(final int d) {
	final int digit = d % 10;
	final String litSegments = SevenSegmentDigits.DIGIT_DEFINITIONS[digit];
	short segmentBits = 0x00;
	for (int i = 0; i < litSegments.length(); i++) {
		final char ch = litSegments.charAt(i);
		final int bitNumber = TO_TF_SEGMENTS_LUT.charAt(ch - 'A') - 'A';
		segmentBits |= 1 << bitNumber;
	return segmentBits;
public static void main(final String[] args) throws TinkerforgeException, IOException {
	go();
Something like an additional "displayValue(uint16 value, bool useTrailingZeros)" wouldn't hurt in the API. I wrote it on my TODO list (which is pretty long ;)).
But in the meantime i think you could also use startCounter with valueFrom and valueTo set to the same value.
