Geschrieben February 27, 2017 at 14:5727. Feb 2017 For a Master Brick 2.1 receiving after 34 to 50% error message - tried several times. 1) Could not flash Brick: Timeout while reading from address 0x400E0A08. 2)Removed all connected bricklets, writing went thru but during verification receiving error: Could not flash Brick: Length error while reading from address 0x00400000 3)Master brick is connected to Raspberry Pi. Latest Brick Deamon / Viewer are installed. 4)Switched to a Windows PC. Flashing went successful. Any hints why under Raspberry Pi a flashing error occurs.?
Geschrieben February 28, 2017 at 13:0528. Feb 2017 Hard to say, since it failed at random times during the flashing it seems to be something indeterministic. Perhaps the voltage of the RPi USB port was not high enough because of too much power draw by other USB devices?
