Geschrieben July 23, 2018 at 10:0723. Jul 2018 Hi! Given that the load Bricklet 2.0 has a 24 bit ADC, I am wondering why it is restricted to grams and doesn't go below thid. Is it possible to tweak the API somehow to allow lower weight measurements? BR Aris
Geschrieben July 23, 2018 at 11:0323. Jul 2018 It is not restricted to anything, you can calibrate it with any unit you want. During calibration when you put 100g on it, just tell it that you put 1000g on it. Now the unit is 1/10g. But there is a lot of noise in the 24 bits, so you will have to average for some period to get a stable value.
Geschrieben July 23, 2018 at 14:2223. Jul 2018 Autor Thank you very much for your reply! I believe that for the application that I want it 0.1g will be enough. Will also try 0.01g and see how it goes. I don't need a fast response since I will combine it with a linear movement system like the one you have for the camera.
