Cannot connect to the master brick. Winerror 10061
I just got my master brick. I see a master brick device, but cannot see the master brick in brick viewer.
I have got the latest Windows 10 updates installed. I can't find a brick daemon in the services. What is the problem? And more important how can I fix this problem?
This worked. I couldn't find Brick Daemon install. On the website it said that for windows 10 you did not need to install Brick Daemon.
I see how you can interpret the docs this way: The section about the manual driver installation says
Quote
Windows 8, 8.1 and 10
Since Windows 8 no driver for Bricks is needed anymore. Windows 8 and later recognizes Bricks automatically.
However this only means, that you don't have to install the driver, you still have to install Brick Daemon itself. I've clarified this in the documentation.
