Geschrieben June 29, 2021 at 19:1329. Jun 2021 Hello, Has anyone been able to use the StepperBrick (or SSB) with the Clearpath Teknic Motors? https://www.teknic.com/model-info/CPM-SDSK-2310D-RLN The reason I ask is that these motor have a built-in encoder/driver so I just need to send data signals (steps) to the motors. The motor receive a direct power from a 24vdc power source so the SD/SSD only need to send the data signals? Any help is appreciated, Thanks, Shaffin.
Geschrieben June 30, 2021 at 10:4130. Jun 2021 It looks like this motor has a step and direction pin for control. Take a look at the Industrial Digital Out 4 2.0: https://www.tinkerforge.com/de/shop/industrial-digital-out-4-v2-bricklet.html It can control the direction pin and also has PWM functionality to generate fast steps.
Geschrieben June 30, 2021 at 12:0730. Jun 2021 Autor Hello Borg, Can you please explain how that would work? Are you suggesting that using the industrial-digital-out bricklet (paired with a master brick), and generate the pulses manually to drive the step and direction? Or can the pulses coming from the SB/SSB be directed to the industrial-digital-out bricklet? Thanks, Shaffin. bearbeitet June 30, 2021 at 23:3630. Jun 2021 von shaffin
