disable blue led on master brick?
hello,
i'd like to ask.. is there a software way to turn off the bright blue led on master? thank you, jose
In the bricklib/utility/init.c you must comment the both lines
led_on(LED_STD_BLUE);
led_tick_task(tick_type);
out.
After compiling and flashing this new firmware, the blue led will be disabled.
Firmware compiling tutorial: http://www.tinkerforge.com/en/doc/Software/Firmwares_And_Plugins.html#firmwares-and-plugins
out.
Behold the power of Open Source. 8)
  • 1 year later...
There is an API to disable the status led since Master Brick firmware 2.3.2.
