Dear TinkerForge,
We recently bought a GPS Bricklet unit and we would like to have some more details about the data received in the callbacks.
We successfully used the coordinate callback as explained here: https://www.tinkerforge.com/en/doc/Software/Bricklets/GPS_Bricklet_C.html#c-c-gps-bricklet
The data contains also the EPE value which we read about here: https://www.nps.gov/gis/gps/WhatisEPE.html
What we did not understand is which confidence interval is used: 50%, 68%, 95%, 99.7?
We need this information to calculate the position covariance (standard deviation) following this approach: https://en.wikipedia.org/wiki/Standard_deviation#Rules_for_normally_distributed_data
Many thanks,
Guido
Ok, looking through the Datasheet by myself, maybe I found it at page 16: https://github.com/Tinkerforge/gps-bricklet/raw/master/datasheets/FGPMMOPA6H.pdf
Position Accuracy Without aid:3.0m (50% CEP)
DGPS(SBAS(WAAS,EGNOS,MSAS)):2.5m (50% CEP)
But I do not know how to relate this fixed CEP specification (which seems the best case) with the variable EPE measurement coming from the GPS Bricklet (often I receive about 1.3m, which is surprisingly low)... can I consider them equivalent measures? ???
Based on your question about getting covariance values for the GPS errors, it sounds like you are working on a Kalman filter to fuse GPS and IMU data.  Is this the case?  I am interested in the same thing but need someone to talk to about the actual kalman filter implementation.  If you are working on the kalman filter I'd like to converse with you.  My email is andycruce@comcast.net.
