Geschrieben (bearbeitet)
Hello,
I have a question about discovery of devices with Ruby. Enumeration supplies the numeric device_identifier for each device, for instance 2103 for a 'LED Strip Bricklet 2.0'.
See documentation.
Next steps would be to load the file defining the matching class, and to initialize an instance of that class:
require 'tinkerforge/bricklet_led_strip_v2'
Tinkerforge::BrickletLEDStripV2.new ...
In other words, I need the name of the matching class for a '2103 device' and the file which defines that class.
Tinkerforge::DEVICE_DISPLAY_NAMES only maps device_identifier to device_display_name.
How do I map numeric device_identifier to class and file?
One way would be to load all 139 device classes, and than loop through all Tinkerforge::Device descendants until I find the one with the matching DEVICE_IDENTIFIER constant. That sounds like a really bad idea.
Has anyone figured this out yet?
bearbeitet von Superp
a %#@& typo
Tinkerforge::DEVICE_DISPLAY_NAMES is internal for error message purposes.
What you're looking for is a device factory. The Ruby bindings don't have that.
  Am 1.12.2020 um 10:46 schrieb Superp:
Expand
That's not a bad idea at all, that basically how Brick Viewer solves this problem. But instead of doing a linear search, Brick Viewer builds a dictionary that maps device identifier to device class and then uses that dictionary to do the lookup efficiently.
What are you trying to build that requires a device factory?
Hi Photron,
Thanks for responding. I am basically just a lazy programmer who likes magic.
What I have done so far is write a little bit of Ruby that 1) takes stock of Device descendants. 2) requires one of TF's source-files. 3) takes stock again and compares to (1) to identify any newly defined class. 4) gets DEVICE_IDENTIFIER and DEVICE_DISPLAY_NAME from the newly defined class. 5) Repeats for all source-files.
This generates a device_info.txt which maps device_identifier, device class, source-file, and device_display_name. You can use any of these four to look up the other three.
This is my third week of using TF and I hope to make it part of a fairly big project.
So, I think I found a working solution, which I'll share here in case anyone else runs into the same limitation.
Tinkerforge.device_info 2103
=> [2103, "LED Strip Bricklet 2.0", ["Tinkerforge::BrickletLEDStripV2", "bricklet_led_strip_v2"]]
and
my_devices = Tinkerforge.connect.discover
Source here.
