duaw Geschrieben November 27, 2022 at 11:09 Geschrieben November 27, 2022 at 11:09 Hallo! Ich möchte ab und an eine weitere Instanz des Brickv starten. Eine erste Suche im Forum hat nicht erbracht, dass diese Frage schon mal gestellt wurde. Es geht: open -n /Applications/Brickv.app startet eine weitere Instanz. Cheers, Uwe 1 Zitieren
Superp Geschrieben November 27, 2022 at 11:26 Geschrieben November 27, 2022 at 11:26 Thanks for this, very helpful. Would be even better if Brickv supported arguments, to connect without further interaction: open -n /Applications/Brickv.app/ --args pi3.local Zitieren
photron Geschrieben December 2, 2022 at 17:17 Geschrieben December 2, 2022 at 17:17 Am 27.11.2022 um 11:26 schrieb Superp: Would be even better if Brickv supported arguments, to connect without further interaction: Expand Will be part of the next brickv release 2.4.23, scheduled for next week. 1 Zitieren
Superp Geschrieben December 3, 2022 at 09:22 Geschrieben December 3, 2022 at 09:22 (bearbeitet) Update 22-Dec-2022: Implemented in Brickv 2.4.23, integrated into Tinderfridge 0.13.0. That would be great, @photron. Note to self: It is not necessary to specify the path to Brickv. On my Mac this works too: open -n -a Brickv This is shorter, and works when Brickv is installed in a different directory (I have it in ~/Applications). Brickv may be spelled all-lowercase brickv, too. Thinking about integrating this with Tinderfridge. Also: Brickv commit bearbeitet December 22, 2022 at 13:14 von Superp Zitieren
