Wifi Extension documentation
At one point in the docs, you write "At the end, press “Save WIFI Configuration” to save the configuration."
Could you please also explain what this save does precisely? Where is this config saved? In the Extension? In a Master Brick? On your local control machine?
I just upgraded my Master Brick firmware from 2.0.4 to 2.0.5 and my Wifi Extension fails to associate with my AP. Do I need to reconfigure this from scratch again?
Basically, please enhance the docs. Thanks!
