Bericht: WARP3 Pro mit evcc und SoC ohne Cloud-Daten
ich würde gebeten meine Lösung hier mal kurz zu beschreiben.
Ich nutze:
2x WARP3 Pro
Cupra Tavascan VZ
Seat Mii Electric
2x WiCAN OBD2-CAN Adapter von MeatPi (WICAN-OBD-C3)
Auf einem Ubuntu Server läuft die aktuelle evcc Version und ein Mosquitto Broker.
Das WiCAN Modul hat die Firmware v4.12-102-ge1d0a09.
Hier die Config vom WiCAN für den Mii:
  "config": {
    "wifi_mode": "APStation",
    "ap_ch": "1",
    "sta_ssid": "XXX",
    "sta_pass": "XXX",
    "sta_security": "wpa2",
    "can_datarate": "500K",
    "can_mode": "normal",
    "port_type": "tcp",
    "port": "3333",
    "ap_pass": "XXX",
    "protocol": "auto_pid",
    "ble_pass": "123456",
    "ble_status": "disable",
    "sleep_status": "disable",
    "sleep_volt": "13.1",
    "sleep_time": "16",
    "batt_alert": "disable",
    "mqtt_en": "enable",
    "mqtt_url": "mqtt://10.10.10.10",
    "mqtt_port": "1883",
    "mqtt_user": "",
    "mqtt_pass": "",
    "keep_alive": "30",
    "mqtt_tx_topic": "wican/tx",
    "ap_auto_disable": "enable",
    "mqtt_tx_en": "disable",
    "mqtt_rx_topic": "wican/rx",
    "mqtt_rx_en": "disable",
    "mqtt_status_topic": "mii/status",
    "mqtt_elm327_log": "disable"
  "auto_pid_car_data": {
    "cars": [
        "car_model": "Seat Mii",
        "init": "",
        "pids": []
  "auto_pid": {
    "initialisation": "ATSP6;ATST96;",
    "grouping": "disable",
    "autopid_polling": "enable",
    "group_dest_type": "Default",
    "destination": "",
    "cycle": "5000",
    "car_specific": "disable",
    "ha_discovery": "disable",
    "pids": [
        "Name": "SoC",
        "Init": "ATSH7E5;ATCRA7ED;",
        "PID": "22028C",
        "Expression": "B4/2.4",
        "MinValue": "0",
        "MaxValue": "100",
        "Period": "10000",
        "Type": "MQTT_WallBox",
        "Send_to": "mii/soc"
        "Name": "Range",
        "Init": "ATSH714;ATCRA77E;",
        "PID": "2222E0",
        "Expression": "(B4*256)+B5",
        "MinValue": "0",
        "MaxValue": "250",
        "Period": "10000",
        "Send_to": "mii/range"
        "Name": "Odometer",
        "PID": "2202BD",
        "Expression": "((B6*65536)+(B7*256)+B9)",
        "MinValue": "",
        "MaxValue": "",
        "Period": "10000",
        "Send_to": "mii/odometer"
    "std_pids": [],
    "standard_pids": "enable",
    "ecu_protocol": "9"
Hier die Config vom WiCAN für den Tavascan:
  "config": {
    "ap_ch": "1",
    "sta_ssid": "XXX",
    "sta_pass": "XXX",
    "port_type": "tcp",
    "port": "3333",
    "ap_pass": "XXX",
    "sleep_time": "16",
    "mqtt_user": "",
    "mqtt_pass": "",
    "keep_alive": "30",
    "mqtt_status_topic": "tavascan/status",
    "cars": [
        "car_model": "VW: ID",
        "init": "ATST96;ATFCSD300000;ATFCSM1;",
        "pids": [
            "pid": "22028C1",
            "pid_init": "ATSP7;ATCP17;ATSHFC007B;ATFCSH17FC007B;ATCRA17FE007B;",
            "parameters": [
                "name": "SOC",
                "expression": "B4*0.461-10.64",
                "unit": "%",
                "class": "battery",
                "period": "5000",
                "min": "0",
                "max": "10000",
                "type": "MQTT_WallBox",
                "send_to": "tavascan/soc"
            "pid": "222AB62",
            "pid_init": "ATSP6;ATCP18;ATSH710;ATFCSH710;ATCRA77A;",
            "parameters": [
                "name": "RANGE",
                "expression": "(B5*256)+B6",
                "unit": "km",
                "class": "distance",
                "period": "5000",
                "min": "",
                "max": "",
                "send_to": "tavascan/range"
            "pid": "22295A",
            "pid_init": "ATSP7;ATCP17;ATSHFC0076;ATFCSH17FC0076;ATCRA17FE0076;",
            "parameters": [
                "name": "ODOMETER",
                "expression": "[B4:B6]",
                "unit": "km",
                "period": "5000",
                "min": "0",
                "max": "",
                "send_to": "tavascan/odometer"
  "auto_pid": {
    "initialisation": "",
    "destination": "",
    "cycle": "5000",
    "car_specific": "enable",
    "pids": [],
    "std_pids": [],
    "standard_pids": "disable",
    "ecu_protocol": "6"
Beim Tavascan gibt es aktuell mit der Firmware und mit den Einstellungen auch keinen Alarm, wenn der PKW abgeschlossen ist...
In evcc ist die Konfiguration dann wie folgt, als Benutzerdefiniertes Gerät:
title: Seat Mii
icon: car
capacity: 32
phases: 2
soc:
  source: mqtt
  topic: mii/soc
range:
  source: mqtt
  topic: mii/range
odometer:
  source: mqtt
  topic: mii/odometer
features:
- welcomecharge
onIdentify:
  mode: pv
Und gleiches für den Tavascan:
title: Cupra Tavascan
icon: car
capacity: 77
phases: 3
soc:
  source: mqtt
  topic: tavascan/soc
range:
  source: mqtt
  topic: tavascan/range
odometer:
  source: mqtt
  topic: tavascan/odometer
features:
- welcomecharge
onIdentify:
  mode: pv
Also der Mosquitto Broker, der auf dem Unbuntu Server läuft, ist der Zentrale Datenaustauschpunkt. Dieser wird sowohl von den Wallboxen, WiCAN Modulen und vom evcc verwendet um die entsprechenden Infos auszutauschen.
In evcc ist bei den Wallboxen ein Standard Fahrzeug hinterlegt und das Update Verhalten steht auf "immer", das Update-Intervall auf 1 Minute und das interpolieren ist deaktiviert.
In der Garage ist ein Access Point und sobald eines der Autos in diese Reichweite gelangt wird der SoC an den MQTT Broker gesendet, evcc bekommt die Informationen und zeigt diese an. Ist der PKW nicht in Reichweite, dann zeigt evcc nur die zuletzt erhaltenen Werte an.
Also das funktioniert hier so wirklich super...
Stefan
Für den OBD2 Port gibt es nur den WICAN und den WICAN PRO.
Der einfache reicht aber für diese Zwecke hier völlig aus.
Nutze ihn auch schon seit gut 6 Monaten mit unserem Ioniq um den SOC an EVCC zu senden.
Klappt auch hier einwandfrei.
@Raudi
Was hat das für eine Funktion ?
features:
- welcomecharge
Wird damit das Vorwärmen aktiviert, wenn das Kabel steckt ?
Hallo @Ben77 @Raudi
Ist bekannt ob:
Am 9.2.2026 um 10:34 schrieb Ben77:
auch für einen Skoda Elroq Modelljahr 2025/2026 funktioniert?
Einfach nur nach WICAN-OBD-C3 in Google suchen und den ersten nicht gesponserten Link zum Mouser Shop.
Das "welcomecharge" ist z.B. bei E-Autos der MEB Plattform wichtig, damit da beim anstecken nicht die rote LED an geht. Dadurch wird sofort beim anstecken mit dem beladen begonnen und wenn keine Sonne da ist, nach dem Abschalt-Timer gleich wieder beendet. Wenn beim anstecken kein Strom anliegt, dann leuchtet die LED an PKW nach dem weiß blinken nach einem Moment rot...
Also ich habe bei mir die ID.Serie Settings genutzt, daher denke ich, dass der Elroq sicherlich auch funktioniert.
Hier gibt es auch noch umfangreiche Infos: https://github.com/meatpiHQ/wican-fw
@meierchen006
Woher schließt Du denn, dass Mouser den Artikel in einem deutschen Lager verfügbar hat? Mouser ist so ein klitzekleiner Elektronik-Distributor der weltweit Läger betreibt.
Ein Blick auf die Herstellerwebsite hat beide Anbieter gelistet.
Somit, entweder bei Mouser bestellen oder nach dem zweiten Anbieter. Mehrwertsteuer, ggf. Einfuhrumsatzsteuer und ggf. Gebühren für zolltechnische Abwicklung beachten falls ein Eigenimport in Betracht gezogen wird.
@meierchen006 und Du glaubst also allen Ernstes, dass hinter ner Münchner Nummer auch ein Lager ist?
Das ist ne Telefonnummer von nem Callcenter der wo auch immer sitzt oder ggf. einem Vertriebsbüro.
Ich würde vorschlagen, dass Du jetzt mal eine Suchmaschine nutzt und nach Mouser Electronics und Lager oder Hauptlager schaust. Dann solltest Du erkennen mit wem Du es zu tun hast bei Mouser.
Die spielen in der Liga wie RS Components oder Amazon für elektronisch Bauteile. Eigentlich alle Sendungen von denen kommen aus deren "klitzekleinen" Hauptlager in den USA.
Oder bestellst halt beim Hersteller MeatPii in Australien wenn Dir Mouser nicht zusagt. Da dürften die Versandkosten noch spannender sein.
Und dann auch GERNE wieder zurück zum ( technischen) Thema des Threads!
@meierchen006 ,
ich habe noch einen WiCAN in der Schublade liegen, den ich nicht nutzen kann, weil bei meinem ID.4 reproduzierbar die Alarmanlage losgeht, wenn der Wagen abgeschlossen ist und auf den OBD-Bus zugegriffen wird. 🚨
Bei Interesse gerne PM…
Hast du das schon mit der Firmware-Version von Raudi getestet?
Hallo @poohnet
Danke für das Angebot, aber ich möchte im Moment noch darauf verzichten. Ich muss erstmal mein Auto so kennen lernen, und wenn das ganze viel Programmiertätigkeit braucht ist das nichts für mich. Habe noch den einen oder anderen Bericht im Netz gefunden, ist doch ziemlich kompliziert.
Und ein ID4 sollte auch ziemlich ähnlich mit meinem Elroq sein, dieser hat aktuell die Firmware 5.6 drauf. Ich. Warte lieber noch ab.
Am 9.2.2026 um 19:50 schrieb poohnet:
@meierchen006 ,
Teste noch mal mit der Firmware, die ich oben genannt habe. Mit der vorherigen war es bei meinem Tavascan auch so, mit der neuen nicht mehr. Irgendwas hat sich da geändert.
Edit: Man sollte evtl. doch die folgenden Posts alle erstmal lesen. 😄 Ja so wie MatzeTF auch schon schrieb...
bearbeitet von Raudi
Am 9.2.2026 um 18:56 schrieb on-off:
Ich habe damals gleich 2 bestellt, ob wohl ich zuerst nur einen gebraucht habe, dann waren es "keine" Versandkosten mehr...
Seitdem ich die ersten Tests gemacht (und wahrscheinlich die Nerven unserer Nachbarn arg strapaziert 😂) habe, liegt der Dongle ungenutzt in der Schublade. Aber besten Dank für den Hinweis, dann teste ich das nochmal mit der aktuellen Firmware...
Am 10.2.2026 um 07:27 schrieb poohnet:
Ja, das kenne ich, sowas blödes. Mir war das auch zuerst nicht bewusst und habe das Auto beim Kollegen abgestellt mit dem ich ne Fahrgemeinschaft habe und dann einige Minuten später hat die Nachbarin vom Kollegen angerufen, dass da permanent der Alarm los geht. Man kann das Auto dann ja aus der Ferne öffnen, und damit dem Alarm abstellen, aber wird die Tür dann nicht physisch geöffnet, dann schließt er wieder ab und das ganze geht von vorn los. Also mussten wir umkehren...
  • 3 months later...
Ich bekomme es einfach nicht hin, dass der e-up den SoC und Range gleichzeitig aktualisiert. Ich hatte schon mal eine WiCAN-Konfig, da wurde nur der Range größer beim Laden, aber SoC wurde nur in dem Moment aktualisiert, wo der WiCAN in den WLAN-Empfangsbereich kam.
Im Moment empfange ich SoC, Range und Odometer - aber nur der SoC wird während des Ladens aktualisiert, der Range bleibt gleich.
@Raudi Steigt bei dir der Range während Du lädst und er der SoC steigt?
P.S. Als die Ladung gestoppt wurde, wurde der Range-Wert aktualisiert,
bearbeitet von eweri
So - ich bin wieder etwas schlauer - wie immer gilt: Kaum macht man es richtig - schon funktioniert es! 😀
Im Gegensatz zu @Raudi habe ich auf meinem alten WiCAN schon die Firmware 4.21 und aus einem Grund den ich nicht verstehe, empfehlen die Hersteller die Anbindung an Home Assistant per http ("Home Assistant webhook support"), nicht per mqtt. So weit nicht schlimm, da man Home Assistant so konfigurieren kann, dass es alle bekannten Sensoren im mqtt-Broker ablegt. So kann man ganz elegant Geräte, die kein mqtt können aber sich per Home Assistant ansprechen lassen doch per mqtt steuern.
Tja und nun zu meinem Fehler:
Da die Werte nicht per mqtt sondern per Web-Hook übertragen wurden tauchen die im mqtt-Broker etwas anders auf:
Schickt der WiCAN seine Werte per mqtt hat der Topic diese Form (kann man komplett frei wählen): "mein_wican/mein_unterpunkt/soc" - der SoC-Wert befindet sich also direkt in dem Punkt "soc"
Schickt der WiCAN seine Werte per Web-Hook hat der Topic z.B. diese Form (von Home Assistant WiCAN-Plugin vorgegeben): "homeassistant/sensor/meinbereich_http_wican_meinemacadresse_local_soc/" - das ist aber nur ein Pfad, der eigentliche Wert steht dann in "state", also der vollständige Topic um auf den Wert vom SoC zu zugreifen ist dann "homeassistant/sensor/meinbereich_http_wican_meinemacadresse_local_soc/state"
Jetzt haben die Werte SoC, Odometer und Range in evcc auch passende Werte.
Ich hoffe das hilft einigen.
Und jetzt kann mich Volkswagen mal 😉
