Seit dem Update ist die Solarprognose nicht mehr verfügbar
Seit dem letzten Update ist der Status meiner Warp2 „gelb“. Grund ist, dass die PV Ertragsprognose keine Werte hat.
Zuerst dachte ich, dass dauert einfach etwas, aber auch heute stehen die Daten nicht zur Verfügung.
Vielen Dank und Grüße Michael
Hier dito - Log:
2026-05-11 12:55:19,166 | solar_forecast | Forecast download failed: ESP_ERR_MBEDTLS_SSL_HANDSHAKE_FAILED (0x801A); SSL - A field in a message was incorrect or inconsistent with other fields (0x6600)
2026-05-11 12:55:19,189 | solar_forecast | Next solar forecast API call will be in 30 minutes
2026-05-11 12:55:19,202 | solar_forecast | Error while downloading solar forecast: ESP_ERR_HTTP_CONNECT (0x7002)
2026-05-11 12:55:19,203 | solar_forecast | Next solar forecast API call will be in 30 minutes
2026-05-11 13:25:19,659 | solar_forecast | Forecast download failed: ESP_ERR_MBEDTLS_SSL_HANDSHAKE_FAILED (0x801A); SSL - A field in a message was incorrect or inconsistent with other fields (0x6600)
2026-05-11 13:25:19,682 | solar_forecast | Next solar forecast API call will be in 30 minutes
2026-05-11 13:25:19,694 | solar_forecast | Error while downloading solar forecast: ESP_ERR_HTTP_CONNECT (0x7002)
2026-05-11 13:25:19,695 | solar_forecast | Next solar forecast API call will be in 30 minutes
2026-05-11 13:35:21,949 | remote_access | Opening connection 2 for user 0
2026-05-11 13:35:22,832 | remote_access | Connection 2 for user 0 connected
2026-05-11 13:36:34,750 | remote_access | Opening connection 4 for user 0
2026-05-11 13:36:35,606 | remote_access | Connection 4 for user 0 connected
2026-05-11 13:39:28,720 | remote_access | Closing connection 2 for user 0
2026-05-11 13:55:20,150 | solar_forecast | Forecast download failed: ESP_ERR_MBEDTLS_SSL_HANDSHAKE_FAILED (0x801A); SSL - A field in a message was incorrect or inconsistent with other fields (0x6600)
2026-05-11 13:55:20,173 | solar_forecast | Next solar forecast API call will be in 30 minutes
2026-05-11 13:55:20,186 | solar_forecast | Error while downloading solar forecast: ESP_ERR_HTTP_CONNECT (0x7002)
2026-05-11 13:55:20,186 | solar_forecast | Next solar forecast API call will be in 30 minutes
Seit letztem SW-Update (warp3_firmware_2_10_2_69fdc0c5_merged - zuvor mit warp3_firmware_2_10_1_69e9e031_merged keine Probleme) - hängt vielleicht mit den wieder hinzugefügten Zertifikaten zusammen?
Log file angehängt...
warp3-2eN4-Debug-Report-2026-05-11T13-54-58-570.txt
Edited by CptHildi
Gibt bald™ ein neues Firmware-Release mit einem Fix.
Für die technisch Versierten: Der Server der Solarvorhersage verwendet TLS 1.3-Signaturalgorithmen in TLS 1.2, was mit dem letzten Update der TLS-Bibliothek verboten wurde, obwohl die Kombination offensichtlich im Feld verwendet wird. 🙄
Am 11.5.2026 um 00:34 schrieb MatzeTF:
Bitte lade einen Debug-Report runter (unter System → Ereignis-Log) und hänge ihn hier an.
Am 11.5.2026 um 15:07 schrieb MatzeTF:
Danke bei mir ist das Selbe ))
Matze wann könnten wir mal das mit der Batteriesteuerung für den Fox H3 Pro angehen ?
Mfg
Ich weiß nichts von einem Fox H3 Pro. Anscheinend ist das auch dein erster Post hier.
Wenn du Batteriesteuerung für einen weiteren Wechselrichter haben möchtest, mach bitte einen neuen Thread auf und poste alle relevanten Informationen, die du anbieten kannst.
Richtig ist mein erster Post hier.
Wir hatten letztes Jahr mal Telefonischen und Mail Kontakt nach der Implementierung des 2 Speichers Für den H3 Pro.
Werde ich dann tun, Vielen Dank
Wahrscheinlich dann aber nicht mit mir. Wenn du schon per Mail Kontakt mit einem Kollegen hattest, kannst du natürlich auch ihm mailen, statt im Forum zu posten.
Ich kann es dir nicht sagen, dachte du seist Matthias, der Damals Zugriff auf mein Energiemanager bekommen hat und auch noch immer hat :) und Mails die ich auch wegen oben genannten Fehler dort hingesendet habe, wurden nicht beantwortet. Vielleicht ist der Kollege auch nicht mehr im Unternehmen.Cih mache einfach demnächst ein neuen Post auf wegen der Batteriesteurung und dann sehen wir weiter, Vielen Dank für eure Tolle Arbeit und den Guten Support
😅 Na Dann ist das mehr als verwirrend. @photron hat sich nun übrigens auch auf die Mail gemeldet. Alles in Ordnung und gut das noch alle im Unternehmen sind ,) Weiter so☺️
Als ergänzender Hinweis: ich hatte jetzt 2x innerhalb von 24 h mit 2.10.2 einen Total-Aufhänger der WB - keine Verbindung mehr zum Web-Servers (weder lokal noch remote), keine Antwort auf Ping im LAN (wired), nur einen physikalischen Link. Umstecken auf anderen Switch-Port hat keine Änderung gebracht (Link, aber keine Reaktion auf Ping). 2x durch Pon neu gestartet, dadurch natürlich auch keine (letzten) Log-Einträge vor dem Hänger... Bin auf 2.10.1 zurück...
Edited by CptHildi
