Hello,
I'm testing the weather station with PHP.
For WeatherStationWebsite.php I use:
<?php
require_once('Tinkerforge/IPConnection.php');
require_once('Tinkerforge/BrickletAmbientLight.php');
require_once('Tinkerforge/BrickletHumidity.php');
require_once('Tinkerforge/BrickletBarometer.php');
use Tinkerforge\IPConnection;
use Tinkerforge\BrickletAmbientLight;
use Tinkerforge\BrickletHumidity;
use Tinkerforge\BrickletBarometer;
$ipcon = new IPConnection();
$brickletAmbientLight = new BrickletAmbientLight("enG", $ipcon);
$brickletHumidity = new BrickletHumidity("eFY", $ipcon);
$brickletBarometer = new BrickletBarometer("eUy", $ipcon);
$ipcon->connect("localhost", 4223);
$illuminance = $brickletAmbientLight->getIlluminance()/10.0;
$humidity = $brickletHumidity->getHumidity()/10.0;
$air_pressure = $brickletBarometer->getAirPressure()/1000.0;
$temperature = $brickletBarometer->getChipTemperature()/100.0;
$response = array (
    "illuminance"  => "Illuminance: $illuminance Lux",
    "humidity"    => "Humidity: $humidity %RH",
    "air_pressure" => "Air Pressure: $air_pressure mbar",
    "temperature"  => "Temperature: $temperature °C",
print_r(json_encode($response));
But the result is:
{"illuminance":"Illuminance: 1.7 Lux","humidity":"Humidity: 68.6 %RH","air_pressure":"Air Pressure: 1001.318 mbar","temperature":null}
What is the correct code to retrieve the temperature from the barometer bricklet?
I've changed the number into 10.0, 100.0, 1000.0 and 10000.0, but it all gave the same result, then I've removed the division altogether but the result stays on "null".
PHP Version 5.4.4-14+deb7u2
BCMath support enabled
include_path .:/usr/share/php:/usr/share/pear
Recent download: pear install Tinkerforge.tgz
And may I add that WeatherStation.php does work and gives me a correct temperature.
But I cannot get a temperature with WeatherStationWebsite.php.
If you print $temperature, is that also "null"?
Your PHP seems to evaluate "Temperature: $temperature °C" as null. I am not sure why that is. Perhaps you can try to change the string bit for bit, to find what excatly the reason is!
It seems that the ° in front of the C causes the problem.
By omitting the ° I get a response: {"illuminance":"Illuminance: 838.1 Lux","humidity":"Humidity: 61 %RH","air_pressure":"Air Pressure: 1013.163 mbar","temperature":"Temperature: 20.46 C"}
Adding a ° gives always a null no mater where it is put.
Is ° a not accepted character in PHP?
utf-8 encoding wasn't the problem.
I fixed it as follows:
Changed:  "temperature"  => "Temperature: $temperature °C"
To:      "temperature"  => "Temperature: $temperature &degC"
Or:      "temperature"  => "Temperature: $temperature &#176C"
So the °C was changed to &decC or to &#176C
This gives the correct response:  Temperature: 18.83 °C
