Geschrieben June 23, 2013 at 09:5023. Jun 2013 Can the Wifi and Ethernet extensions be combined in any interesting ways, or are they mutually exclusive?
Geschrieben June 24, 2013 at 13:3924. Jun 2013 You can use them in the same LAN, but that is about it .
Geschrieben June 25, 2013 at 05:3825. Jun 2013 They aren't usable in the same stack. You can use them together with RS485 but not WiFi and LAN together. The reason for it is, that there is only one extension per stack allowed which has the connection to controlling devices.
