Failed install of brickview
For the life of me I can't get brickview to install.I keep getting the same error message:
pi@raspberrypi ~ $ sudo apt-get install python python-qt4 python-qt4-gl python-qwt5-qt4 python-opengl python-serial
Reading package lists... Done
Building dependency tree
Reading state information... Done
python is already the newest version.
python-serial is already the newest version.
python-serial set to manually installed.
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
python-opengl : Depends: libglu1-mesa but it is not going to be installed or
                          libglu1
                Depends: freeglut3 but it is not going to be installed
python-qt4 : Depends: libqt4-declarative (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqt4-designer (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqt4-help (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqt4-script (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqt4-scripttools (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqt4-test (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqt4-xmlpatterns (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqtassistantclient4 (>= 4.6.3) but it is not going to be installed
              Depends: sip-api-8.1
python-qt4-gl : Depends: libqt4-opengl (>= 4:4.8.0-1~) but it is not going to be installed
python-qwt5-qt4 : Depends: libqwt5-qt4 (>= 5.2.2) but it is not going to be installed
                  Recommends: libqwt-dev but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Has anyone got a solution? Much appreciated
I keep getting the same error message no matter what permutation I try. This apparently stopd my Brickv from installing.Her it is
brickv : Depends: python-qt4 but it is not going to be installed
          Depends: python-qt4-gl but it is not going to be installed
          Depends: python-qwt5-qt4 but it is not going to be installed
          Depends: python-opengl but it is not going to be installed
pm-utils : Depends: powermgmt-base but it is not going to be installed
            Recommends: vbetool but it is not installable
            Recommends: hdparm but it is not going to be installed
Are you there Remote Control?
Have you tried the recommendation from above?
Der Loetkolben
Danke Loetkolben. Ja hab ich schon probiert. Aus meiner verzweiflung habe ich mein 16 Gig Sandisk formatted and started all over again following judiciously the instruction on Tinkerforge. I thought I had it; when I got to the stage of answering wether or not I agree to surrendering some 550 odd meg of disk space. I happily selected y for yes !!! wait for it! I got and "abort" Why for heavens sake?? I thought perhaps answering n for no would do it; but no it resulted in the same "abort" responds. I have a newly formatted 60 gig Sandisk?
Sorry, I am not sure if you prefer english. Let me know. I live in Brisbane/Australia. Though I do speak German.
Cheers
Karl
I use Python 3.2 I think. The one that installs from NOOBS, it just offers Python at install doesn't say which version. The SD card is a 16 gig Sandisk Xtra speed. I have gone back and re-formatted and re-installed NOOBS twice. It just will not install the qt4 qt5gl et cetera. The brickdeamon installed okay. There is also a Brickv Icon in my "other" directory but clicking on it produces nothing, it is just a shortcut, that seems to be leading nowhere. Thanks for trying. The -f switch seems to make no difference.
Yes I tried the -f switch I think these files are missing on my RPi (Python 3.2)
Would be nice if someone knew where to find them!
It doesn't seem to matter what call I make the same error report appears:
          Depends: python-serial but it is not going to be installed
# note: the –f switch makes no difference
I got the same message when trying to install geany.i.e.
sudo apt-get install geany.
Thank you chaps
The following proved to resolve this issue:
Run this first:
sudo apt-get install libusb-1.0-0 libudev0 pm-utils
Wait till this process finishes !! then run:
wget
http://download.tinkerforge.com/tools/brickd/linux/brickd_linux_latest_armhf.deb
sudo dpkg -i brickd_linux_latest_armhf.deb
Again, wait till this is done, then run:
sudo apt-get -f install python python-qt4 python-qt4-gl python-qwt5-qt4 python-opengl python-serial
Wait till done, then run:
wget http://download.tinkerforge.com/tools/brickv/linux/brickv_linux_latest.deb
sudo dpkg -i brickv_linux_latest.deb
Cheers
