May 12, 2012 at 04:00 AMMay 12, 2012 Hello all, I'm just starting to play with the servo brick. I think I may have pressed the erase and reset buttons when the servo was plugged into my computer, and connected to a motor. It doesn't light up now, and my computer doesn't seem to see it. What should I do?
May 12, 2012 at 08:31 PMMay 12, 2012 Doesn't it register with your computer at all? If the Server Brick is in the bootloader it should at least be shown as some atmel device or something. You can find a description on how to flash a new firmware on Bricks here: http://www.tinkerforge.com/doc/Software/Firmwares_And_Plugins.html#flash-firmware-on-a-brick
May 13, 2012 at 08:03 PMMay 13, 2012 Author Thanks so much. That worked after some trial and error. I guess I panicked and didn't think of flashing with updated software.
