Geschrieben January 6, 2022 at 09:456. Jan 2022 Hello, For a Master Brick 3.1 (HW version 3.0.0, FW 2.5.1, Ruby bindings 2.1.29), it seems #get_usb_voltage always returns 0 (zero). The documentation says "Returns the USB voltage. Does not work with hardware version 2.1". I am asking because I have a stack powered via USB by a power pack.
Geschrieben January 6, 2022 at 15:376. Jan 2022 Hello, it's right it is not working since version 2.1. Before that we had a analog measurement of the USB voltage to detect if USB is connected. With version 2.1 we have introduced a more stable solution which unfortunately makes it impossible to measure the voltage.
Geschrieben January 7, 2022 at 09:047. Jan 2022 Autor Well no, I would not say it is fixed, it's documented. This is costing me a bit.
