Announcements
There was no central place for announcements about new versions of Brick Daemon and Viewer, the different programming language bindings as well as firmwares and plugins. This thread is going to improve this.
New software and hardware will be announced here :)
  • Replies 548
  • Aufrufe 344,5k
Joystick Bricklet Plugin 1.1.4
  • Fix threshold period logic. Since version 1.1.3 the Position Reached callback was triggered despite a Threshold Period of 0 (Callback disabled).
Download: Plugin
Master Brick Firmware 1.2.0
  • RS485 Support
Download: Firmware
Brick Viewer 1.1.2 does not work in combination with this firmware version because of a bug in the viewer. This bug is fixed in Brick Viewer 1.1.3, updating is strongly recommended.
Bindings: C/C++ 1.0.13, C# 1.1.6, Java 1.0.12, PHP 1.0.7, Python 1.0.15, Ruby 1.0.4
Firmwares: DC Brick 1.1.3, IMU Brick 1.0.7, Master Brick 1.2.1, Servo Brick 1.1.3, Stepper Brick 1.1.4
  • Added function to read out microcontroller temperature(get_chip_temperature)
  • Added function to reset Bricks and stacks of Bricks (reset)
Download Bindings: C/C++, C#, Java, PHP, Python, Ruby
Download Firmwares: DC Brick, IMU Brick, Master Brick, Servo Brick, Stepper Brick
Bindings: C/C++ 1.0.16, C# 1.1.9, Java 1.0.15, PHP 1.0.10, Python 1.0.18, Ruby 1.0.7
  • Fix direction of get_all_data_period function in Stepper Brick API
  • Fix wrong datatype in receive thread for Python 3 (Python only)
  • Ensure that stdint.h defines INT32_MAX (C/C++ only)
  • Make add_device thread-safe
  • Ensure that destroy can end the receive thread correctly (Ruby only)
  • Ensure correct shutdown order of threads
Download: C/C++, C#, Java, PHP, Python, Ruby
Brick Daemon 1.0.9
  • Reduce Windows and Mac OS installer size
  • Avoid race condition when enumerating USB devices on Linux
  • Use more expressive log file name and correct line endings on Windows
  • Don't cancel pending USB transfers to avoid segfault in libusb on Linux
  • Update libusb to make USB 3.0 work on Windows
Bindings: C/C++ 1.0.18, C# 1.1.10, Delphi 1.0.2, Java 1.0.16, PHP 1.0.11, Python 1.0.19, Ruby 1.0.8
Plugins: IO-4 Bricklet 1.1.1, IO-16 Bricklet 1.1.2
Brick Viewer 1.1.6
  • Fix race condition in bindings function add_device
  • Add monoflop functionality to IO-4 and IO-16 Bricklet
  • Display chip temperature in Brick Viewer
Download Bindings: C/C++, C#, Delphi, Java, PHP, Python, Ruby
Download Plugins: IO-4 Bricklet, IO-16 Bricklet
Download Brick Viewer: Windows, Linux, Mac OS X
