Announcements
  • Replies 550
  • Aufrufe 345k
Firmwares: Master Brick 1.3.2
Please update your Master Brick to this version if you are using the WIFI Extension, in prior versions it drops incoming messages if many callbacks are used!
  • Add receive ringbuffer for WIFI Extension (prevent oveflow due to callbacks)
Download Firmwares: Master Brick
Brick Viewer 1.1.8
  • Show Brick UID in Bricklet flashing dialog
  • Make device table sortable
  • Remove chip temperature column
  • Fix serial port enumeration for ports with non-ASCII names
  • Add Stack ID, UID, FW Version and Reset button to each tab
  • Add AP and Ad Hoc support to Master Brick plugin
Downloads: Windows, Linux, Max OS X
Bindings: C/C++ 1.0.20, C# 1.1.12, Delphi 1.0.4, Java 1.0.18, PHP 1.0.13, Python 1.0.21, Ruby 1.0.10
  • Add getter for WIFI buffer status information [All]
  • Change WIFI certificate getter/setter to transfer bytes instead of a string [All]
  • Add API for setting of WIFI regulatory domain [All]
  • Add reconnect functionality to IPConnection (for WIFI Extension) [C/C++, C#, Delphi, Java, Python]
  • Add API for Industrial Bricklets: Digital In 4, Digital Out 4 and Quad Relay [All]
  • Use StringBuilder when deserializing strings [C#, Java]
  • Avoid a race condition in expectedResponseFunctionID handling [C#, Java]
  • Make TDevice.GetVersion work as documented [Delphi]
  • Add inline code documentation [Delphi]
  • Fix semaphore deadlock on timeout [Java]
  • Trim NUL characters from strings properly [Java, Python]
Download: C/C++, C#, Delphi, Java, PHP, Python, Ruby
Brick Viewer 1.1.11
Barometer Bricklet Plugin 1.1.0
Bindings: C/C++ 1.0.22, C# 1.1.14, Delphi 1.0.6, Java 1.0.20, PHP 1.0.15, Python 1.0.23, Ruby 1.0.12
  • Replace calibate function in Barometer Bricklet API with getter/setter for reference air pressure of the altitude calculation
Download Brick Viewer: Windows, Linux, Mac OS X
Download Plugin: Barometer Bricllet
Download Bindings: C/C++, C#, Delphi, Java, PHP, Python, Ruby
Brick Viewer 1.1.12
  • Automatically restart Bricks after successful flashing a new firmware
  • Check for invalid characters in SSID and key for WIFI Extension, only ASCII without the quotation mark is allowed
  • Show WIFI encryption mode correctly
  • Show version numbers in flashing dialog
  • Remember the last 5 hosts
  • Add Check-for-Updates functionality for connected Bricks and Bricklets
Firmwares: Master Brick 1.4.2
  • Add support for usage of two extensions at the same time
  • Supported combinations:
    • WIFI top/RS485 Master bottom
    • RS485 Master top/WIFI bottom
    • RS485 Master top/Chibi Slave bottom
    • Chibi Slave top/RS485 Master bottom
    • Chibi Master top/RS485 Slave bottom
    • RS485 Slave top/Chibi Master bottom
Bindings: C/C++ 1.0.23, C# 1.1.15, Delphi 1.0.7, Java 1.0.21, PHP 1.0.16, Python 1.0.24, Ruby 1.0.13
  • Add get_usb_voltage function to Master Brick API [All]
  • Add Barometer Bricklet examples [All]
  • Handle difference between currentThread and current_thread to support Python 2.5 [Python]
  • Changed callback_queue from class variable to instance variable [Python]
Brick Viewer 1.1.13
  • Switch from green to dark green in graphs for better contrast on gray
  • Show Barometer Bricklet altitude also in feet
  • Fix progress dialog for Bricklet flashing
  • Handle old names for Temperature IR and Distance IR Bricklets in Check-for-Updates dialog
  • Automatically restore IMU factory calibration after flashing
  • Improve flashing verification speed by reading whole flash pages
  • Improve progress dialog for firmware and plugin discovery in flashing window
  • Add basic FreeBSD support
  • Add button to restore factory calibration to IMU calibration window
  • Add missing image for Dual Replay Bricklet plugin
