Announcements
  • Replies 552
  • Aufrufe 351,3k
Firmwares: DC Brick 1.1.6, IMU Brick 1.0.9, Master Brick 1.4.6, Servo Brick 1.1.5, Stepper Brick 1.1.9
  • Change Bricklet Context size from 250 to 256 (through bricklib).
  • This gets rid of the alignment issues with Bricklet Plugins in newer GCC versions.
Download Firmwares: DC Brick, IMU Brick, Master Brick, Servo Brick, Stepper Brick
Brick Daemon 1.0.11
  • Don't broadcast GetStackID responses, avoids confusing clients
  • Update libusb-1.0.dll to support the 2nd generation of Renesas USB 3.0 controllers
  • Lock the PID file on Linux to prohibit starting multiple instances
Brick Viewer 1.1.14
  • Make Bricklet flashing fail early on verification error
  • Improve message for WIFI power mode changes
  • Verify UID format before writing it to a Bricklet
  • Fix discovering of plugins for Industrial Bricklets on tinkerforge.com
  • Switch button text from state to action for Dual Relay Bricklet plugin
  • Improve monoflop handling for Industrial Bricklets
Brick Viewer 1.1.19
  • Updates and Flashing Dialog show only releases with major version 1 (in preparation for Protocol 2.0)
  • Icons and images are now always loaded from the correct directory
  • Should work on older Mac OS X versions (< 10.8) again
Plugins: LCD20x4 Bricklet 2.0.1, LCD16x2 Bricklet 2.0.1
Bindings: C/C++ 2.0.1, C# 2.0.1, Delphi 2.0.1, Java 2.0.1, PHP 2.0.1, Python 2.0.1, Ruby 2.0.1
  • Add custom character support for LCD20x4 and LCD16x2 Bricklet
Download Plugin:LCD20x4 Bricklet, LCD16x2 Bricklet
Download Bindings: C/C++, C#, Delphi, Java, PHP, Python, Ruby
Brick Viewer 2.0.1
  • Add custom character support to LCD Bricklet plugins
  • Handle no-internet-connection case probably in updates dialog
  • Add more information to Bricklet UID and plugin writing error messages
  • Make Protocol 1.0 Bricklet auto-detection more robust
Brick Daemon 2.0.1
  • Add socket peer name to related log messages
  • Don't accept an empty string as valid integer value in config file
  • Reject 0 as port number in config file
  • Report config errors to log file
Tested on Mac OS X 10.7.3 und 10.8.2. Brick Daemon 2.0.0 crashed on Mac OS X 10.7.5 immediately after start up.
