Announcements
  • Replies 553
  • Aufrufe 361,6k
Bindings: C/C++ 2.0.6, C# 2.0.7, Delphi 2.0.9, Java 2.0.7, PHP 2.0.7, Python 2.0.7, Ruby 2.0.7, VB.NET 2.0.3
  • Add Ethernet Extension support to Master Brick API [all]
  • Avoid non-portable usage of bit fields [C/C++]
  • Only send disconnect probe if there was no packet send or received for 5s [all]
  • Fix deserialization of chars in Python 3 [Python]
  • Fix (u)int16 big endian handling [C/C++]
  • Workaround struct packing bug in GCC 4.7 [C/C++]
  • Avoid race condition during socket closing [C#, Java]
  • Add IMU orientation and Barometer averaging API [all]
  • Fix locking for disconnect probe thread detecting a socket error [Java]
Download: C/C++, C#, Delphi, Java, PHP, Python, Ruby, VB.NET
Plugins: Ambient Light Bricklet 2.0.1, Analog In Bricklet 2.0.2, Current12 Bricklet 2.0.1, Current25 Bricklet 2.0.1, Humidity Bricklet 2.0.1, Linear Poti Bricklet 2.0.1, Rotary Poti Bricklet 2.0.1, Temperature IR Bricklet 2.0.1, Voltage Bricklet 2.0.1, Voltage/Current Bricklet 2.0.2
  • Don't send threshold callback twice erroneously anymore
Downloads: Ambient Light Bricklet, Analog In Bricklet, Current12 Bricklet, Current25 Bricklet, Humidity Bricklet, Linear Poti Bricklet, Rotary Poti Bricklet, Temperature IR Bricklet, Voltage Bricklet, Voltage/Current Bricklet
Brick Viewer 2.0.5
  • Add commandline tool for flashing bricks (thanks to Jan)
  • Try to avoid UI hang during connect
  • Add plugin for Ethernet Extension
  • Show WIFI password/key with * characters by default
  • Add spin boxes for new averaging API in Barometer Bricklet plugin
  • Less jittery plot widgets
  • Make errors during Brick reset in flash process non-fatal
Brick Viewer 2.0.6
  • Remove averaging of analog value from Distance IR Bricklet plugin
  • Set min/max degree correctly if all servos are selected in Servo Brick plugin
  • Support splitted LCD 20x4 Bricklet plugin
  • Fix monoflop time update if Go button is clicked in quick succession
  • Add plugins for PTC Bricklet and Industrial Dual 0-20mA Bricklet
Firmwares: DC Brick 2.0.2, IMU Brick 2.0.3, Servo Brick 2.0.4, Stepper Brick 2.0.4
  • Use tick_task to detect usb connect/disconnect instead of interrupt. This allows to ignore glitches that come back through the diode to the USB detect pin. This feature was already implemented in the Master Brick and is now moved to the bricklib. Thus it is no default behavior for all Bricks.
Download Firmwares: DC Brick, IMU Brick, Servo Brick, Stepper Brick
Bindings: C/C++ 2.0.7, C# 2.0.8, Delphi 2.0.10, Java 2.0.8, PHP 2.0.8, Python 2.0.8, Ruby 2.0.8, VB.NET 2.0.4
  • Add support for PTC Bricklet and Industrial Dual 0-20mA Bricklet [all]
  • Workaround for GCC 4.7 struct packing bug is only necessary on Windows [C/C++]
  • Avoid breaking strict-aliasing [C/C++]
  • Fix Windows Phone support [C#]
Brick Daemon 2.0.6
  • Workaround struct packing bug in MinGW GCC 4.7
  • Add simple event log viewer tool for Windows
  • Prohibit starting a second instance on Windows
  • Check for USB device additions/removals changes on SIGUSR1
  • Ignore SIGPIPE and handle socket write errors properly
Downloads: Windows, Linux (amd64, i386, armhf), Mac OS X
