Announcements
  • Replies 551
  • Aufrufe 350k
Bindings: C/C++ 2.0.13, C# 2.0.13, Delphi 2.0.15, Java 2.0.14, PHP 2.0.12, Python 2.0.13, Ruby 2.0.13, Shell 2.0.5, VB.NET 2.0.9
  • Add Get/SetClockFrequency function to LED Strip Bricklet API [all]
  • Fix mixup of Set/GetDateTimeCallbackPeriod and Set/GetMotionCallbackPeriod in GPS Bricklet API [all]
  • Support addressing types of Intertechno and ELRO Home Easy devices in Remote Switch Bricklet API [all]
Download: C/C++, C#, Delphi, Java, PHP, Python, Ruby, Shell, VB.NET
Plugins: Ambient Light Bricklet 2.0.3, Analog In Bricklet 2.0.4, Barometer Bricklet 2.0.2, Distance IR Bricklet 2.0.2, Distance US Bricklet 2.0.1, Humidity Bricklet 2.0.2, Industrial Dual 0-20mA Bricklet 2.0.1, Joystick Bricklet 2.0.3, Linear Poti Bricklet 2.0.2, Line Bricklet 2.0.1, Moisture Bricklet 2.0.1, PTC Bricklet 2.0.1, Rotary Encoder Bricklet 2.0.1, Rotary Poti Bricklet 2.0.2, Sound Intensity Bricklet 2.0.1, Temperature Bricklet 2.0.2, Temperature IR Bricklet 2.0.2, Voltage/Current Bricklet 2.0.4
  • Fix wrong length for GetDebounce packet (through brickletlib).
Download Plugin: Ambient Light Bricklet 2.0.3, Analog In Bricklet 2.0.4, Barometer Bricklet 2.0.2, Distance IR Bricklet 2.0.2, Distance US Bricklet 2.0.1, Humidity Bricklet 2.0.2, Industrial Dual 0-20mA Bricklet 2.0.1, Joystick Bricklet 2.0.3, Linear Poti Bricklet 2.0.2, Line Bricklet 2.0.1, Moisture Bricklet 2.0.1, PTC Bricklet 2.0.1, Rotary Encoder Bricklet 2.0.1, Rotary Poti Bricklet 2.0.2, Sound Intensity Bricklet 2.0.1, Temperature Bricklet 2.0.2, Temperature IR Bricklet 2.0.2, Voltage/Current Bricklet 2.0.4
Brick Viewer 2.0.9
  • Support Get/SetClockFrequency in LED Strip Bricklet plugin
  • Show "motion detected" in red in Motion Detector Bricklet plugin
  • Support Intertechno and ELRO Home Easy addressing types in Remote Switch Bricklet plugin
Bindings: Perl 2.0.1
  • Put all packages into Tinkerforge namespace
  • Fix signature of get/set_response_expected(_all) functions to match the documentation
  • Handle error code in response packages
  • Add Error class to report an error code in addition to the error message
Download: Perl
Firmware: Master Brick 2.2.0
  • Add support for Websockets for Ethernet Extension
  • Add support for authentication of Ethernet/WIFI Extension
  • Reset on USB Resume, to get a clean state
  • Increase USB hotplug detect threshold
  • SPI stack slave gives up immediately if message length too long
Download: Master Brick
Bindings: C/C++ 2.1.0, C# 2.1.0, Delphi 2.1.0, Java 2.1.0, JavaScript 2.0.0, LabVIEW 2.1.0, Mathematica 2.1.0, Perl 2.1.0, PHP 2.1.0, Python 2.1.0, Ruby 2.1.0, Shell 2.1.0, VB.NET 2.1.0
  • Add authentication support to IPConnection and Master Brick API [all]
  • Initial JavaScript bindings release [JavaScript]
  • Rewrite endian handling logic to work without detecting the actual host endian [C/C++]
  • Exit receive thread on socket shutdown by peer to avoid triggering multiple disconnected callbacks [C#]
  • Add TDeviceBase class as empty base class for all devices [Delphi]
  • Add TinkerforgeListener and DeviceListener as base interfaces for all listeners [Java]
  • Escape special HTML characters in JavaDoc [Java]
  • Make IPConnection locks proper members of the class instance [Perl]
  • Make Brick and Bricklet classes proper subclasses of Device [Perl]
  • Don't overwrite auto_reconnect option in set_timeout function [Perl]
  • Properly handle socket shutdown in receive thread [Ruby]
Download: C/C++, C#, Delphi, Java, JavaScript, LabVIEW, Mathematica, Perl, PHP, Python, Ruby, Shell, VB.NET
Brick Viewer 2.1.0
  • Add authentication configuration for Ethernet and WIFI Extension to Master Brick plugin
  • Add WebSocket configuration for Ethernet Extension to Master Brick plugin
  • Fix temperature averaging bug in Barometer Bricklet plugin
  • Fix Dual Button Bricklet left/right permutation
  • Reduce long-term memory usage by properly removing widgets on device disconnect
