Announcements
Brick Daemon 2.1.0
  • Add authentication support (disabled by default)
  • Add WebSocket support (port 4280, disabled by default)
  • Make USB device lookup more robust in case of some USB driver bugs on Windows
  • Update bundled libusb to 1.0.18 on Mac OS X, fixes a SIGFPE bug
  • Update bundled libusb to 1.0.18 on Windows, adds support for Intel and AMD USB 3.0 root hubs
  • Improve handling of request packets with invalid length in the header
  • Handle rare case of socket_receive failing with EWOULDBLOCK
  • Don't lose connection to USB devices on host-resume-from-suspend on Linux and Mac OS X (requires pm-utils on Linux)
  • Increase upper limits for pending requests and USB write queues
  • Add socket_send queue for clients, enqueue packet instead of disconnecting client if socket_send would block
  • Only dispatch response to the first client with a matching pending request, fixes response duplication
  • Replies 553
  • Aufrufe 352k
  • 4 weeks later...
Bindings: C/C++ 2.1.1
  • Add extern "C" markup to all files to force proper symbol names in C++
  • Explicitly use ANSI version of WinAPI functions to support UNICODE builds on Windows
  • Add simple library Makefile for Linux
  • Fix race condition between device destruction and callback dispatch
Download: C/C++
Bindings: C/C++ 2.1.2, C# 2.1.1, Delphi/Lazarus 2.1.1, Java 2.1.1, JavaScript 2.0.1, LabVIEW 2.1.1, Mathematica 2.1.1, MATLAB/Octave 2.0.1, Perl 2.1.1, PHP 2.1.1, Python 2.1.1, Ruby 2.1.1, Shell 2.1.1, VB.NET 2.1.1
  • Add support for WS2811 and WS2812 to LED Strip Bricklet API [all]
Brick Viewer 2.1.1
  • Use a more recent UI style on Windows
  • Store port, authentiation options and secret per host and double host history length
  • Use a signed Brick bootloader driver on Windows
  • Add support for WS2811 and WS2812 to LED Strip Bricklet plugin
Plugin: LED Strip Bricklet 2.0.4
  • Use measured timings instead of faulty datasheet values
Download: LED Strip Bricklet
Firmwares: DC Brick 2.0.3, IMU Brick 2.0.4, Master Brick 2.2.2, Servo Brick 2.0.5, Stepper Brick 2.0.5
  • Remove rarely used USB hotplug feature (prevents accidiential stack restart after heatup)
Download: DC Brick, IMU Brick, Master Brick, Servo Brick, Stepper Brick
Plugin: LED Strip Bricklet 2.0.5
  • Frame duration of 0 now means that no more frames shall be set
  • Set RGB values at least two times to make sure that they are really written
  • Fix possible overflow if Brick with two Bricklet connectors is used
Brick Daemon 2.1.1
  • Add live debug log view to logviewer.exe on Windows
  • Include signed version of the Brick bootloader driver for Windows
  • Workaround race condition in USB hotplug handling on Linux
  • Fix crash if client with pending responses disconnects
  • Fix possible mismatch while handling responses for identical requests
  • Avoid broadcasting unexpected responses in most cases
Bindings: C/C++ 2.1.4, C# 2.1.2, Delphi/Lazarus 2.1.2, Java 2.1.2, JavaScript 2.0.2, LabVIEW 2.1.2, Mathematica 2.1.2, MATLAB/Octave 2.0.2, Perl 2.1.2, PHP 2.1.2, Python 2.1.2, Ruby 2.1.2, Shell 2.1.2, Visual Basic .NET 2.1.2
  • Add support for Color, NFC/RFID and Solid State Relay Bricklet [all]
  • Rename bindings/ folder to source/ in ZIP file [C/C++, Delphi]
  • Replace System.console() usage with an Eclipse compatible pattern in examples [Java]
  • Move NPM package into nodejs/ folder of ZIP file [JavaScript]
  • Add main Tinkerforge.js script to simplify direct usage of the Node.js source code [JavaScript]
  • Only use MSG_NOSIGNAL if it's really defined [Perl]
  • Remove CPAN package from ZIP file, include relevant files into the source/ folder [Perl]
  • Get rid of the egg and easy_install, use setuptools directly or pip instead [Python]
Brick Viewer 2.1.2
  • Rename main.exe to brickv.exe on Windows
  • Make rainbow work better on small LED counts and add moving-dot mode to LED Strip Bricklet plugin
  • Allow double click anywhere in a device tree row to jump to the corresponding tab
