Announcements
  • Replies 551
  • Aufrufe 348,8k
Bindings: C/C++ 2.1.9, C# 2.1.8, Delphi/Lazarus 2.1.9, Java 2.1.7, JavaScript 2.0.7, LabVIEW 2.1.7, Mathematica 2.1.7, MATLAB/Octave 2.0.7, Perl 2.1.7, PHP 2.1.7, Python 2.1.7, Ruby 2.1.7, Shell 2.1.7, VB.NET 2.1.7
  • Add support for CO2, OLED 64x48 and 128x64, Thermocouple and UV Light Bricklet
  • 4 weeks later...
Bindings: C/C++ 2.1.10, C# 2.1.9, Delphi/Lazarus 2.1.10, Java 2.1.8, JavaScript 2.0.8, LabVIEW 2.1.8, Mathematica 2.1.8, MATLAB/Octave 2.0.8, Perl 2.1.8, PHP 2.1.8, Python 2.1.8, Ruby 2.1.8, Shell 2.1.8, Visual Basic .NET 2.1.8
  • Add support for Real-Time Clock Bricklet [all]
  • Break GPS Bricklet API to fix types of altitude and geoidal separation values (get_altitude function and ALTITUDE callback) [all]
RED Brick Image 1.8
  • Disable unnecessary OTG detection on Mini-USB port
  • Increase image size from 5GB to 7GB
  • Enable more HID and Bluetooth kernel drivers
  • Install sunxi Mali GPU driver into the correct directory
  • Manually install snmp-mibs-downloader to workaround Debian packaging problem
  • Update Brick Daemon to version 2.2.2
  • Update Brick Viewer to version 2.3.3
  • Update all API bindings: C/C++ 2.1.10, C# 2.1.9, Delphi/Lazarus 2.1.10, Java 2.1.8, JavaScript 2.0.8, LabVIEW 2.1.8, Mathematica 2.1.8, MATLAB/Octave 2.0.8, Perl 2.1.8, PHP 2.1.8, Python 2.1.8, Ruby 2.1.8, Shell 2.1.8, Visual Basic .NET 2.1.8
Download: RED Brick Image
Plugin: Thermocouple Bricklet 2.0.1
  • Signed 19 bit to signed 32 Bit conversion fixed (In 2.0.0 positive temperatures that have bit 15 set are shown negative)
Download: Thermocouple Bricklet
Please note: Because of a bug in Brick Viewer this firmware has to be updated by and, you can not use the "Auto-Update-Function". This will be fixed in the next version of Brick Viewer.
Firmware: IMU 2.0 Brick 2.0.3
  • Use DMA for I2C communication with BNO055.
  • This allows for better SPI stack communication throughput, since we don't have to disable the interrupts for the whole communication.
Download: IMU Brick
  • 4 weeks later...
Brick Viewer 2.3.5
  • Add support for WIFI Extension 2.0, CAN Bricklet and RGB LED Bricklet
  • Add synchronous rectification and decay controls to the Stepper Brick plugin
  • Reduce minimal height for several plugins to make Brick Viewer fit onto smaller screens: IMU Brick 2.0, Industrial Digital In 4 Bricklet, Industrial Digital Out 4 Bricklet and Industrial Quad Relay Bricklet
  • Add edit buttons to RED Brick program wizard list editors
  • Add dialog to change RED Brick program file permissions
  • Make 3D view of IMU Brick 2.0 plugin detachable
  • Fix enumeration problem in Data Logger device dialog
  • Add support for Real-Time Clock Bricklet alarms
  • Unify GUI layout of plugins with a plot widget
  • Improve plot widget rendering performance by avoiding full updates
Bindings: C/C++ 2.1.11, C# 2.1.10, Delphi/Lazarus 2.1.11, Java 2.1.9, JavaScript 2.0.9, LabVIEW 2.1.9, Mathematica 2.1.9, MATLAB/Octave 2.0.9, Perl 2.1.9, PHP 2.1.9, Python 2.1.9, Ruby 2.1.9, Shell 2.1.9, Visual Basic .NET 2.1.9
  • Add support for WIFI Extension 2.0 to Master Brick API [all]
  • Add support for CAN Bricklet and RGB LED Bricklet [all]
  • Add DateTime and Alarm callbacks to Real-Time Clock Bricklet API [all]
  • Avoid MSVC warnings about deprecated gethostbyname and strdup and about strncpy being unsafe [C/C++]
  • Use generics for newer Delphi versions [Delphi/Lazarus]
  • Use stream sockets as a fallback if the sockets extension is missing
Avoid long/unbound connection timeout [Python]
Fix array ellipsis for non-char options [shell]
