Announcements
  • Replies 548
  • Aufrufe 344k
Note: Because of a bug during transfer of the last 256 bytes from the EEPROM of a Bricklet to the Brick flash it is theoretically possible that any Bricklet above a specific size has undefined behavior for some functions under some circumstances.
We don't know if this bug is present for any of the released firmwares (it is hard to determine and reproduce). We recommend to update all of the Bricks, just in case.
Firmwares: DC Brick 2.3.2, IMU Brick 2.3.2, IMU 2.0 Brick 2.0.4, Master Brick 2.4.1, Servo Brick 2.3.1, Stepper Brick 2.3.3
  • Make sure to use all chunks when writing firmware
Download: DC Brick, IMU Brick, IMU 2.0 Brick, Master Brick, Servo Brick, Stepper Brick
Brick Viewer 2.3.6
  • Improve WIFI Extension 2.0 flashing speed
  • Handle unknown client status for WIFI Extension 2.0 correctly
  • Add moving average length spinbox to Distance US Bricklet plugin
  • Add support for RGBW LEDs, channel mapping and SK6812RGBW (NeoPixel RGBW), LPD8806 and ADA102 (DotStar) chip types to LED Strip Bricklet plugin
Plugin: LED Strip Bricklet 2.0.6
  • Fix green flash after reset
  • Make FrameRendered callback configurable
Download: LED Strip Bricklet
Note: This plugin is affected by the flash transfer bug, that was fixed in the current Brick firmwares. Therefore, this plugin should only be used with an up-to-date Brick firmware.
Bindings: C/C++ 2.1.12, C# 2.1.11, Delphi/Lazarus 2.1.12, Java 2.1.10, JavaScript 2.0.10, LabVIEW 2.1.10, Mathematica 2.1.10, MATLAB/Octave 2.0.10, Perl 2.1.10, PHP 2.1.10, Python 2.1.10, Ruby 2.1.10, Shell 2.1.10, Visual Basic .NET 2.1.10
  • Add support for RGBW LEDs, channel mapping and SK6812RGBW (NeoPixel RGBW), LPD8806 and ADA102 (DotStar) chip types to LED Strip Bricklet API [all]
  • Add support for Universal Windows Platform (UWP), see the Visual Studio 2015 project file source/Tinkerforge/TinkerforgeUWP.csproj [C#]
Brick Daemon 2.2.3
  • Update bundled libusb to 1.0.20 on Windows, add support for Intel Alpine Ridge USB 3.1 controller
  • Update bundled libusb to 1.0.20 on Mac OS X
  • Merge --debug and --libusb-debug options
  • Properly quote path to brickd.exe for service registration on Windows
  • Switch to .pkg based installer for Mac OS X
  • Fix crash in RS485 Extension code for RED Brick
  • 4 weeks later...
Brick Daemon 2.3.0
  • Add support for WIFI Extension 2.0 Mesh mode
  • Improve RED Brick SPI stack protocol ACK handling
  • Add Co-MCU Bricklet handling to RED Brick SPI stack protocol
  • Avoid crash due to improperly cancelled USB transfers at device disconnect on Mac OS X
  • Update bundled libusb to 1.0.21 on Windows and Mac OS X
  • Also read config from unsupported Extensions on RED Brick to allow Brick Viewer showing them as unsupported
  • Avoid using Debian specific init script helper functions on Linux
Bindings: C/C++ 2.1.13, C# 2.1.12, Delphi/Lazarus 2.1.13, Java 2.1.11, JavaScript 2.0.12, LabVIEW 2.1.11, Mathematica 2.1.11, MATLAB/Octave 2.0.11, Perl 2.1.11, PHP 2.1.11, Python 2.1.11, Ruby 2.1.11, Shell 2.1.11, Visual Basic .NET 2.1.11
  • Add support for WIFI Extension 2.0 Mesh mode to Master Brick API [all]
  • Add get/set_status_led_config functions to Motion Detector Bricklet API [all]
  • Add sensor and fusion mode configuration functions to IMU Brick 2.0 API [all]
  • Avoid MSVC cast warning [C/C++]
  • Use MSVC stdbool.h if available [C/C++]
  • Fix DNS lookup on Universal Windows Platform (UWP) [C#]
  • Fix $endif / $ifend mixup [Delphi/Lazarus]
  • Use correct CompilerVersion check for generics [Delphi/Lazarus]
  • Avoid compiler bug when assigning constants to a uint64 variable [Delphi/Lazarus]
  • Fix enumerate callback unregistration [Python]
Brick Viewer 2.3.7
  • Warn about unsupported RS485 baud rates and modes on RED Brick
  • Add web interface enable/disable checkbox for WIFI Extension 2.0
  • Show WIFI Extension 2.0 firmware version in setup tab and updates dialog
  • Keep stacks grouped in device table, if sorted by position
  • Add support for WIFI Extension 2.0 Mesh mode to Master Brick plugin
  • Fix race condition in WIFI Extension 2.0 firmware version lookup
  • Also show unsupported Extension in the RED Brick plugin
  • Add dialog to RED Brick network tab to connect to hidden Wi-Fi networks
  • Fix check for downloading firmwares from tinkerforge.com
  • Remove error prone Protocol 1 Bricklet detection logic
