Announcements
Brick Viewer 2.4.19
  • Add support for DC 2.0, Industrial PTC and Silent Stepper Bricklet 2.0
  • Add Data Logger support for DC 2.0, Industrial PTC and Silent Stepper Bricklet 2.0
  • Fix Health Monitor error handling
  • Filter Updates/Flashing and RED Brick Console serial port selection based on USB product- and vendor-ID
  • Replies 551
  • Aufrufe 349,4k
  • 2 months later...
Bindings: Rust 2.0.19
  • Fix compilation issues caused by yanked dependency
  • Add set/get_display_driver functions and DISPLAY_DRIVER constants to E-Paper 296x128 Bricklet API
  • Add simple_get_tag_id function and NFC_BRICKLET_MODE_SIMPLE constant to NFC Bricklet API
Download: Rust
Brick Viewer 2.4.20
  • Hide unused custom line ending controls in hex mode in RS485 Bricklet plugin
  • Reuse thread in Data Logger timer to avoid slow memory leak
  • Fix Data Logger device list clearing on config loading
  • Fix slow memory leak in Data Logger data tab
  • Add firmware version column to Health Monitor dialog
  • Improve udev rule compatibility on Linux
  • Add support for RTC driver config to HAT Brick plugin
  • Add support for simple mode to NFC Bricklet plugin
  • Increase required PySerial version to 3.0
  • Add support for flashing ESP32 (Ethernet) Bricks
  • 2 months later...
Brick Viewer 2.4.21
  • Fix serial port listing on Apple M1 Macs
  • Truncate RED Brick log file view to 10MB
  • Improve hex input mode for RS232 Bricklet 2.0
  • Improve compatibility with Python 3.10
  • Fix OpenGL problems on macOS 12
  • 3 months later...
Bindings: C/C++ 2.1.33, C/C++ for Microcontrollers 2.0.1, C# 2.1.31, Delphi/Lazarus 2.1.32, Go 2.0.12, Java 2.1.32, JavaScript 2.1.34, LabVIEW 2.1.30, Mathematica 2.1.30, MATLAB/Octave 2.0.32, MQTT 2.0.16, Perl 2.1.31, PHP 2.1.30, Python 2.1.30, Ruby 2.1.30, Rust 2.0.20, Saleae 2.0.7, Shell 2.1.32, Visual Basic .NET 2.1.30
  • Add support for GPS Bricklet 3.0 [all]
  • Add set/get_display_driver functions and DISPLAY_DRIVER constants to E-Paper 296x128 Bricklet API [all]
  • Add simple_get_tag_id function and MODE_SIMPLE constant to NFC Bricklet API [all]
  • Add set/get_rtc_driver functions and RTC_DRIVER constants to HAT Brick API [all]
  • Fix out-of-bounds read when passing string literals [C/C++]
  • Set correct buffer to null when streaming out single chunks [C/C++]
  • Fix short write for bool stream-in [C/C++]
  • Only include stdbool.h if compiling for C [C/C++]
  • Use correct snprintf function with older MSVC versions [C/C++]
  • Add .NET 5/6 and .NET Standard 2.0 to NuGet package [C#]
  • Fix race condition in TTimedSemaphore Acquire/Release logic that affected callback handling [Delphi/Lazarus]
  • Use recommended order of modifiers [Java]
  • Fix chunk padding for char streams [MQTT]
  • Fix relative import error handling in Python 3 [Python]
Download: C/C++, C/C++ for Microcontrollers, C#, Delphi/Lazarus, Go, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, MQTT, Perl, PHP, Python, Ruby, Rust, Saleae, Shell, Visual Basic .NET
Brick Viewer 2.4.22
  • Add support for GPS Bricklet 3.0 and ESP32 (Ethernet) Brick
  • Add Data Logger support for GPS Bricklet 3.0
  • Improve plot color palette for dark themes
  • Rework plot timing logic to greatly reduce jitter
  • Draw a vertical line to indicate time jumps in plots
  • Fix driver installation on Windows
  • Upgrade bundled Python to 3.9 on Windows (Windows 8.1 required)
  • 4 weeks later...
  • 4 weeks later...
  • 3 months later...
Firmware: ESP32 Brick 2.0.2, ESP32 Ethernet Brick 2.0.2
  • Add WireGuard support
  • Make authentication secret, listen port and address configurable
  • Add NTP state and synced time to status page
  • Improve firmware update error handling in web interface
  • Update timezone database
  • Improve translations
  • Fix commands without payload via HTTP GET
  • Add reset API for configurations
  • Add reset button to configuration pages
  • Fix firmware hanging after 2^32 ms (~ 49 days 17 hours)
  • Fix access point as fallback not starting correctly
Download: ESP32 Brick, ESP32 Ethernet Brick
Brick Viewer 2.4.23
  • Allow saving config when Modbus master timeout is changed for RS485 Bricklet
  • Enable Python development mode when running from source
  • Fix socket leak on connect error
  • Add manual y-axis scaling for plot widget
  • Remove all driver files for Windows 7 and earlier
  • Fix calibration dialog title for Compass Bricklet plugin
  • Fix Galileo satellite numbers for GPS Bricklet 3.0
  • Add support for IPv6 connections
  • Add commandline options to specify host, port and secret
  • Add tab select menu that stays in the top left corner
  • Fix corner cases in IMU Brick(let) plugin untab handling
  • Add manual firmware list update button if auto-search for updates is disabled
Brick Daemon 2.4.4
  • Add menu entry to clear Live Log in Windows Log Viewer
  • Abort delayed USB stall recovery if device was removed in the meantime
  • Add rate limit for Bricklet error messages
  • Increase libusb requirement from 1.0.6 to 1.0.20
  • Allow to disable mesh gateway
  • Update bundled libusb to 1.0.26.11755 on Windows (Windows Vista or newer required) and macOS
Downloads: Windows, Linux (amd64, i386, armhf, arm64), macOS
Brick Viewer 2.4.24
  • Fix Python dev-mode default handling
  • Do not touch /usr/lib/python3/dist-packages on Debian Linux
  • Convert Debian Linux package build to debhelper
  • Disable ADC calibration for 7p Bricks
  • Add missing pkg_resources dependency on Linux
  • Update all temperature readings with 10 Hz
  • Stop callback emulator from delivering results to destroyed plugins
  • Avoid crash while loading the 3D model in all IMU plugins
  • Avoid PyQt5 import problem with the Qt module
