Announcements
  • 3 months later...
  • Replies 553
  • Aufrufe 352k
  • 3 months later...
Bindings: C/C++ 2.1.34, C/C++ for Microcontrollers 2.0.4, C# 2.1.32, Delphi/Lazarus 2.1.33, Go 2.0.15, Java 2.1.33, JavaScript 2.1.35, LabVIEW 2.1.31, Mathematica 2.1.31, MATLAB/Octave 2.0.33, MQTT 2.0.17, Perl 2.1.32, PHP 2.1.31, Python 2.1.31, Ruby 2.1.31, Rust 2.0.21, Saleae 2.0.8, Shell 2.1.33, Visual Basic .NET 2.1.31
  • Add support for Industrial Dual AC In Bricklet [All]
  • Add FFC shutter mode and normalization to Thermal Imaging Bricklet API [All]
  • Fix System.AppDomain.Unload timeout, avoid crash [LabVIEW]
  • Fix System.AppDomain.Unload timeout [C#, Mathematica, VB.NET]
  • Fix error response check [Go]
  • Fix single chunk streams [Go]
  • Handle empty payload in streamed function calls [MQTT]
  • Remove wrong stream error handling [JavaScript]
  • Add IPv6 support, raises PHP requirement to 7.2.0 [P,HP]
  • Don't leak socket on connect error [Python]
  • Add IPv6 support [Python]
  • Show dropped bytes [Saleae]
  • Fix get-identity call [Shell]
  • Fix --execute with modern Python versions [Shell]
  • Support authentication secret, listen address and port for Arduino ESP32 [µC]
  • Don't count callbacks as unexpected packets [µC]
  • Fix byte offset when splitting packet to be sent [µC]
  • Correctly mark packet as processed if received in setter [µC]
  • Correctly stop waiting for packet when timeout is elapsed [µC]
  • Use correct sequence number when resending proxy packets [µC]
  • Validate header length of received packets [µC]
  • Report local function calls as unsupported instead of timing out [µC]
  • Fix IP address handling with current Arduino ESP32 [µC]
Download: C/C++, C/C++ for Microcontrollers, C#, Delphi/Lazarus, Go, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, MQTT, Perl, PHP, Python, Ruby, Rust, Saleae, Shell,
Brick Viewer 2.4.26
  • Add Data Logger support for Industrial Dual AC In Bricklet
  • Only use Python dev-mode if available
  • Fix health monitor metric errors for ESP32 (Ethernet) Brick
  • Add "@ host:port" to window title if connected
  • Avoid crash when closing Brick Viewer
  • Add function code to Modbus master function selection in RS485 Bricklet plugin
  • 4 weeks later...
Bindings: C# 2.1.33, Delphi/Lazarus 2.1.34, LabVIEW 2.1.32, Mathematica 2.1.32, Visual Basic .NET 2.1.32
  • Handle forced socket read timeout for System.AppDomain.Unload timeout fix correctly when using Microsoft .NET runtime on Linux [C#, LabVIEW, Mathematica, VB.NET]
  • Use macOS specific code for all non-Windows platforms [Delphi]
Download: C#, Delphi/Lazarus, LabVIEW, Mathematica, Visual Basic .NET
  • 4 weeks later...
  • 2 months later...
Firmware: NFC Bricklet 2.1.0
  • Update NXP NfcLibrary
  • Fix input buffer overwrite bug
  • Add support for NFC Forum Type 5 (ISO 15693)
  • Add NDEF support for NFC Forum Type 5 and Mifare Classic
  • Improve card emulation support (now properly works between two NFC Bricklets and with Android/iPhone)
  • Add support for custom tag ID in cardemu mode
  • Remove P2P support
Download: NFC Bricklet
  • 2 months later...
  • 4 weeks later...
Firmware: ESP32 Brick 2.1.0, ESP32 Ethernet Brick 2.1.0
  • Close network connections before reboot
  • Sign firmware updates
  • Fix focus loss when starting to edit device display name
  • Fix localization of names of downloaded files
  • Fix long SSIDs overflowing the web interface layout
  • Show error message if recovery page failed to start factory reset
  • (Only ESP32 Brick) Fix certificate upload
  • Add system language setting
  • Use browser's preferred language for login page translation
  • Don't attempt to connect to servers if no network connection is available
  • Improve time keeping between RTCs, NTP and other time sources
  • Fix missing web interface alert texts
  • Fix WiFi scan results with unexpected characters
  • Fix Caps Lock detection of password inputs
  • Add device info to web interface menu bottom
  • Disconnect least recently active web interface if all connections are in use and a new web interface connects
  • Don't allow setting the web interface listen port to an "unsafe" port
  • Fix colors of disabled inputs in web interface
  • (Only ESP32 Ethernet Brick) Speed up debug report (trace log) download
  • Update core software libraries (ESP-IDF 5.4 and arduino-esp32 3.2)
  • Update timezone database
  • Improve translations
Download: ESP32 Brick, ESP32 Ethernet Brick
  • 3 months later...
Bindings: Go 2.0.16
  • Add support NFC forum tag type 5 to NFC Bricklet API
  • Add CardemuSet/GetTagID function to NFC Bricklet API
  • Add WriteLine2 function to OLED 128x64 Bricklet 2.0 API
  • Add Set/GetMotorStalledCallbackConfiguration functions and MotorStalled callback to Silent Stepper Bricklet 2.0 API
  • Add Set/GetCaptureInputCallbackConfiguration functions and CaptureInput callback to IO-4 Bricklet 2.0 API
  • Fix device identifier check
Download: Go
Bindings: Python 2.1.32
  • Add cardemu_set/get_tag_id function to NFC Bricklet API
  • Add write_line_2 function to OLED 128x64 Bricklet 2.0 API
  • Add set/get_motor_stalled_callback_configuration functions and MOTOR_STALLED callback to Silent Stepper Bricklet 2.0 API
  • Add set/get_capture_input_callback_configuration functions and CAPTURE_INPUT callback to IO-4 Bricklet 2.0 API
Download: Python
  • 4 months later...
