  • Replies 548
  • Aufrufe 343,1k
  • 2 months later...
Firmwares: DC Brick 2.3.0, IMU Brick 2.3.0, Master Brick 2.3.0, Servo Brick 2.3.0, Stepper Brick 2.3.0
  • New SPI protocol for all Bricks (RED Brick-compatible).
  • Increase all versions to 2.3.0 to simplify stack-compatability. All versions >= 2.3.0 are compatible to each other.
  • Master Brick: Add support for hardware version 2.1.
Download: DC Brick, IMU Brick, Master Brick, Servo Brick, Stepper Brick
Brick Viewer 2.2.0
  • Add support for RED Brick
  • Allow to rearrange Brick and Bricklet tabs and detach them from the main window
  • Improve UI for NFC/RFID Bricklet read and write operations
  • Windows installer and drivers are signed now
  • Fix occasional bounce of the connect button
  • Fix UI font selection on Mac OS X 10.9 and 10.10
Brick Daemon 2.2.0
  • Colorized log messages
  • Detect and drop pending requests that will never get a response
  • Mac OS X installer signed on Mac OS X 10.10 to make it pass the Gatekeeper again
  • Enable logrotate for brickd.log on Linux
  • Remove all categories from logging system
  • Handle partial writes if outgoing socket buffer is almost full
Bindings: C/C++ 2.1.5, C# 2.1.3, Delphi/Lazarus 2.1.3, Java 2.1.3, JavaScript 2.0.3, LabVIEW 2.1.3, Mathematica 2.1.3, MATLAB/Octave 2.0.3, Perl 2.1.3, PHP 2.1.3, Python 2.1.3, Ruby 2.1.3, Shell 2.1.3, VB.NET 2.1.3
  • Add support for RED Brick [all]
  • Make listener dispatch methods protected to allow external changes [Java]
  • Add support for Delphi XE on Mac OS X [Delphi]
  • Add workaround for older Delphi versions that lack TThread.CurrentThread [Delphi]
  • Add simple library fpcmake file [Delphi]
  • Handle EINTR error in receive loop [Python]
Bindings: C/C++ 2.1.6, C# 2.1.4, Delphi/Lazarus 2.1.4, Java 2.1.4, JavaScript 2.0.4, LabVIEW 2.1.4, Mathematica 2.1.4, MATLAB/Octave 2.0.4, Perl 2.1.4, PHP 2.1.4, Python 2.1.4, Ruby 2.1.4, Shell 2.1.4, VB.NET 2.1.4
Brick Viewer 2.2.1
  • Exclude file system cache from memory value on RED Brick overview tab
  • Show full list of available wireless networks instead of using a drop-down box on RED Brick network tab
  • Use timeout counter to show RED Brick timeout errors
  • Fix file progress display on RED Brick program upload dialog
  • Add Java main class discovery for already created RED Brick Java programs and make it abortable
  • Improve Java class path handling for RED Brick Java programs
  • Add missing Java part of RED Brick program upload summary
  • Add RED Brick file system settings tab to do file system expansion
RED Brick Images: Full and Fast 1.1
  • Update C# bindings to version 2.1.5
  • Update Brick Viewer to version 2.2.1
  • Fix pin mapping for second Master Extension
  • Add missing Delphi, Octave, Shell and Node.js version information for Brick Viewer
Download: Full, Fast
RED Brick Images: Full and Fast 1.2
  • Update Delphi/Lazarus Bindings to version 2.1.5
  • Fix intermittent missing Loopback-Interface problem
  • Fix mixing setuid flag in /usr/bin/sudo
  • Add gphoto2 and libgphoto2
  • 4 weeks later...
Brick Daemon 2.2.1
  • Improve RED Brick hotplug detection and error handling on Windows
  • Add debug filter to fine-tune debug output
  • Wait for WebSocket handshake completion before sending data
  • Use redapid version as RED Brick firmware version
  • Don't send packet twice after partial write
