Announcements
Bindings: C/C++ 2.1.20, C# 2.1.18, Delphi/Lazarus 2.1.19, Java 2.1.18, JavaScript 2.0.18, LabVIEW 2.1.17, Mathematica 2.1.17, MATLAB/Octave 2.0.18, Perl 2.1.17, PHP 2.1.17, Python 2.1.17, Ruby 2.1.17, Shell 2.1.17, Visual Basic .NET 2.1.17
  • Add support for CAN 2.0, Industrial Counter, Industrial Digital In 4 2.0, Industrial Dual Relay, Industrial Quad Relay 2.0, IO-4 2.0, LED Strip 2.0, Load Cell 2.0, Particulate Matter, PTC 2.0, Real-Time Clock 2.0, RS232 2.0, Sound Pressure Level, Thermocouple 2.0 and Voltage/Current 2.0 Bricklet [all]
  • Add get/set_maximum_timeout functions to NFC Bricklet API [all]
  • Add is_sensor_connected function and SENSOR_CONNECTED callback to PTC Bricklet API [all]
  • Break Humiditiy 2.0, Rotary Encoder 2.0 and Temperature IR 2.0 Bricklet API to fix types for callback threshold min/max configuration [all]
  • Fix string (un)packing for non-ASCII chars [Ruby]
  • Add general streaming support [JavaScript]
  • Replies 551
  • Aufrufe 350,4k
Brick Viewer 2.3.15
  • Add Data Logger support for CAN 2.0, Industrial Counter, Industrial Digital In 4 2.0, Industrial Dual Relay, Industrial Quad Relay 2.0, IO-4 2.0, LED Strip 2.0, Load Cell 2.0, Particulate Matter, PTC 2.0, Real-Time Clock 2.0, Sound Pressure Level, Thermocouple 2.0 and Voltage/Current 2.0 Bricklet
  • Add Data Logger support for logging all stations and sensors with the Outdoor Weather Bricklet
Brick Logger 2.0.7
  • Add support for CAN 2.0, Industrial Counter, Industrial Digital In 4 2.0, Industrial Dual Relay, Industrial Quad Relay 2.0, IO-4 2.0, LED Strip 2.0, Load Cell 2.0, Particulate Matter, PTC 2.0, Real-Time Clock 2.0, Sound Pressure Level, Thermocouple 2.0 and Voltage/Current Bricklet 2.0
Downloads: Windows, Linux, Mac OS X, RED Brick
RED Brick Image 1.12
  • Fix booting with an RS485 Extension present
  • Update Brick Viewer to version 2.3.15
  • pdate all API bindings: C/C++ 2.1.20, C# 2.1.18, Delphi/Lazarus 2.1.19, Java 2.1.18, JavaScript 2.0.18, Octave 2.0.18, Perl 2.1.17, PHP 2.1.17, Python 2.1.17, Ruby 2.1.17, Shell 2.1.17, Visual Basic .NET 2.1.17
Download: RED Brick Image
Brick Daemon 2.3.2
  • Fix notification event name handling on Windows 10 IoT Core
  • Read USB string descriptors instead of faking them on Windows 10 IoT Core
  • Add backward compatibility to RED Brick Image 1.9
  • Update bundled libusb to 1.0.22 on Windows and macOS, this fixes enumeration problems with ASMedia USB hubs, composite devices and bogus USB device address reports on Windows
  • Add MSVC project on Windows
  • Use systemd instead of init.d on Linux, if available
  • Add initial Android support, no precompiled app available yet, brickd for Android has to be compiled from source
Bindings: C/C++ 2.1.21, C# 2.1.19, Delphi/Lazarus 2.1.20, Java 2.1.19, JavaScript 2.1.19, LabVIEW 2.1.18, Mathematica 2.1.18, MATLAB/Octave 2.0.19, Perl 2.1.18, PHP 2.1.18, Python 2.1.18, Ruby 2.1.18, Shell 2.1.18, Visual Basic .NET 2.1.18
  • Add support for Air Quality, Analog Out 3.0, Barometer 2.0, Distance IR 2.0, Dual Button 2.0, Industrial Analog Out 2.0, Industrial Digital Out 4 2.0, Industrial Dual 0-20mA 2.0, Industrial Dual Analog In 2.0, IO-16 2.0, Isolator, LCD 128x64, OLED 128x64 2.0, One Wire, Temperature 2.0 and UV Light 2.0 Bricklet [All]
  • Fix compile errors in Delphi XE [Delphi/Lazarus]
  • Convert all array parameters from static to open to accept dynamic arrays too [Delphi/Lazarus]
  • Fix authentication server nonce packing [Perl]
  • Fix single byte bool array unpacking
Firmwares: Thermocouple Bricklet 2.0 2.0.1, RGB LED Button Bricklet 2.0.1, Industrial Digital In 4 Bricklet 2.0 2.0.1, NFC Bricklet 2.0.2, PTC Bricklet 2.0 2.0.1, Remote Switch Bricklet 2.0 2.0.2, LED Strip Bricklet 2.0 2.0.1, Temperature IR Bricklet 2.0 2.0.2, Solid State Relay Bricklet 2.0 2.0.1, Humidity Bricklet 2.0 2.0.2, Outdoor Weather Bricklet 2.0.1, IO-4 Bricklet 2.0 2.0.1, RS485 Bricklet 2.0.2, Particulate Matter Bricklet 2.0.1, Industrial Quad Relay Bricklet 2.0 2.0.1, GPS Bricklet 2.0 2.0.4, Real-Time Clock Bricklet 2.0 2.0.3, Motion Detector Bricklet 2.0 2.0.1, Analog In Bricklet 3.0 2.0.2, RGB LED Matrix Bricklet 2.0.1, CAN Bricklet 2.0 2.0.1, Sound Pressure Level Bricklet 2.0.2, Industrial Dual Relay Bricklet 2.0.1, Thermal Imaging Bricklet 2.0.2, Voltage/Current Bricklet 2.0 2.0.1, DMX Bricklet 2.0.1, RS232 Bricklet 2.0 2.0.1, Motorized Linear Poti Bricklet 2.0.3, Load Cell Bricklet 2.0 2.0.1, Industrial Counter Bricklet 2.0.1
  • Fix race condition with potential buffer overflow (through bricklib2)
Download: Thermocouple Bricklet 2.0, RGB LED Button Bricklet, Industrial Digital In 4 Bricklet 2.0, NFC Bricklet, PTC Bricklet 2.0, Remote Switch Bricklet 2.0, LED Strip Bricklet 2.0, Temperature IR Bricklet 2.0, Solid State Relay Bricklet 2.0, Humidity Bricklet 2.0, Outdoor Weather Bricklet, IO-4 Bricklet 2.0, RS485 Bricklet, Particulate Matter Bricklet, Industrial Quad Relay Bricklet 2.0, GPS Bricklet 2.0, Real-Time Clock Bricklet 2.0, Motion Detector Bricklet 2.0, Analog In Bricklet 3.0, RGB LED Matrix Bricklet, CAN Bricklet 2.0, Sound Pressure Level Bricklet, Industrial Dual Relay Bricklet, Thermal Imaging Bricklet, Voltage/Current Bricklet 2.0, DMX Bricklet, RS232 Bricklet 2.0, Motorized Linear Poti Bricklet, Load Cell Bricklet 2.0, Industrial Counter Bricklet
Bindings: C/C++ 2.1.22, C# 2.1.20, Delphi/Lazarus 2.1.21, Java 2.1.20, JavaScript 2.1.20, LabVIEW 2.1.19, Mathematica 2.1.19, MATLAB/Octave 2.0.20, Perl 2.1.19, PHP 2.1.19, Python 2.1.19, Ruby 2.1.19, Shell 2.1.19, Visual Basic .NET 2.1.19
  • Break API to fix moving-average-length type in Distance IR Bricklet 2.0 API [All]
Brick Viewer 2.3.16
  • Add Data Logger support for Air Quality, Analog Out 3.0, Barometer 2.0, Distance IR 2.0, Dual Button 2.0, Industrial Dual 0-20mA 2.0, Industrial Dual Analog In 2.0, IO-16 2.0, Temperature 2.0 and UV Light 2.0 Bricklet
  • Add gain control to Load Cell Bricklet 2.0 plugin
  • Show correct unit in UV Light Bricklet plugin
  • Make Real-Time Clock Bricklet (2.0) calibration process more robust
  • Install start menu link for all users on Windows
RED Brick Image 1.13
  • Disable drm_kms_helper polling to solve system stalls every 10 seconds
  • Add Lua 5.3 interpreter
  • Enable loopback device support
  • Update Brick Daemon to version 2.3.2
  • Update Brick Viewer to version 2.3.16
  • Update all API bindings: C/C++ 2.1.22, C# 2.1.20, Delphi/Lazarus 2.1.21, Java 2.1.20, JavaScript 2.0.20, Octave 2.0.20, Perl 2.1.19, PHP 2.1.19, Python 2.1.19, Ruby 2.1.19, Shell 2.1.19 und Visual Basic .NET 2.1.19
Bindings: C/C++ 2.1.23, C# 2.1.21, Delphi/Lazarus 2.1.22, Java 2.1.21, JavaScript 2.1.21, LabVIEW 2.1.20, Mathematica 2.1.20, MATLAB/Octave 2.0.21, Perl 2.1.20, PHP 2.1.20, Python 2.1.20, Ruby 2.1.20, Shell 2.1.20, Visual Basic .NET 2.1.20
  • Add get/set_samples_per_second functions to Humidity Bricklet 2.0 API
  • Add button, slider, graph and tab functions to LCD 128x64 Bricklet API
Firmware: LCD 128x64 Bricklet 2.0.2
  • Fix backlight PWM (value of zero is now completely off)
  • Use CIE 1931 lookup-table for backlight intensity correction
  • Fix Status/Touch LED mixup
  • Add Set/GetTouchLEDConfig API
  • Add API for simple GUI elements with touch support
Download: LCD 128x64 Bricklet 2.0.2
Some bugs were already found and fixed in the new LCD API:
Firmware: LCD 128x64 Bricklet 2.0.3 + 2.0.4 + 2.0.5
  • Fix off-by-one in GUI graph height calcultion
  • Fix bug in GUI remove functions
  • Fix wrong initialization of touch LED
  • Make sure display is updated on GUI remove-event
Download: LCD 128x64 Bricklet 2.0.5
  • 4 weeks later...
