Announcements
  • Replies 550
  • Aufrufe 344,9k
Brick Daemon 2.4.0
  • Add support for HAT (Zero) Brick (SPI connected Bricklets)
  • Install Log Viewer start menu link for all users on Windows
  • Add commandline options to override config, log and PID file location on Linux and macOS
  • Remove accidental dependency to libusb 1.0.20 on Linux
  • Replace Event Log usage with persistent log file on Windows
  • Extend Log Viewer to start/stop brickd, view log file and edit config file on Windows
  • Fix rare crash in WIFI Extension 2.0 mesh packet handling
  • Add support for receiving multiple response packets per USB read transfer
  • Update bundled libusb to 1.0.23-rc1 on Windows and macOS, this fixes problems with ROOT/SYSTEM/0001 USB hubs on Windows
  • Bind to all IP addresses resolved from the listen.address config option, instead of just the first one
Brick Viewer 2.4.5
  • Improve GUI and error handling of RS485 Bricklet plugin
  • Improve WIFI Extension 2.0 configuration validation
  • Handle spectrum stream-out-of-sync error for Sound Pressure Level Bricklet
  • Handle station/sensor loss for Outdoor Weather Bricklet
  • Don't trigger overview updates while RED Brick plugin is not visible
  • Fix duplicated async-reads in RED Brick plugin script manager
  • Enable Retina mode on macOS
  • Fix upload of empty files to RED Brick
  • Fix timezone setting for RED Brick
  • Make WIFI Extension 2.0 flashing more robust by increasing the number of bootloader connection attempts
RED Brick Image 1.14
  • Add Python 3 dependencies for Brick Viewer version >= 2.4.0
  • Update Brick Daemon to version 2.4.0
  • Update Brick Viewer to version 2.4.6
  • Add PIL for Python 2 and 3
  • Update all API bindings: C/C++ 2.1.25, C# 2.1.23, Delphi/Lazarus 2.1.24, Java 2.1.23, JavaScript 2.1.23, Octave 2.0.23, Perl 2.1.22, PHP 2.1.22, Python 2.1.22, Ruby 2.1.22, Shell 2.1.22, Visual Basic .NET 2.1.22
Download: RED Brick Image
Bindings: C/C++ 2.1.26, C# 2.1.24, Delphi/Lazarus 2.1.25, Go 2.0.4, Java 2.1.24, JavaScript 2.1.24, LabVIEW 2.1.23, Mathematica 2.1.23, MATLAB/Octave 2.0.24, MQTT 2.0.7, Perl 2.1.24, PHP 2.1.23, Python 2.1.23, Ruby 2.1.23, Rust 2.0.12, Shell 2.1.23, Visual Basic .NET 2.1.23
  • Add support for Color 2.0, Compass, Distance US 2.0, Energy Monitor, Multi Touch 2.0, Rotary Poti 2.0 and XMC1400 Breakout Bricklet [All]
  • Add Get/SetFilterConfiguration functions to Accelerometer Bricklet 2.0 API [All]
  • Add ConversionTime constants to Voltage/Current Bricklet 2.0 API [All]
  • Fix misaligned array access in callback wrapper function [C/C++]
  • Don't leak the get_random_uint32 symbol [C/C++]
  • Break API to stop mixing object and function pointers for callback functions [C/C++]
  • Allow to pass non-constant values to parameters with constants [Go]
  • Break API to remove enumerate response structure: enumerate callback uses parameters directly, which is more in line with all other callbacks [Go]
  • Increase minimum JDK version from 1.6 to 8 [Java]
  • More robust connection handling [MQTT]
  • Fix init file loading [MQTT]
Brick Viewer 2.4.7
  • Add Data Logger support for Color 2.0, Compass, Distance US 2.0, Energy Monitor, Multi Touch 2.0 and Rotary Poti 2.0 Bricklet
  • Fix latest firmware version discovery if no Internet connection is available
  • Add interpolation and scale factor options to Thermal Imaging Bricklet plugin
  • Download firmware files using HTTPS
  • Updates/Flashing dialog can download Brick Viewer updates
  • Fix WIFI Extension 2.0 flashing to fix web interface
  • Don't try to use invalid IMU Brick calibration
  • Don't crash if OpenGL is not available
  • Correctly handle Modbus response with unknown request in RS485 Bricklet plugin
Brick Viewer 2.4.9
  • Fix Bricklet auto-update crash
  • Allow to choose other versions than the latest when flashing firmwares
  • Allow to write hex bytes in hex mode in RS485 Bricklet plugin
  • Allow to specify coil/register values when writing multiple coils/registers in RS485 Bricklet plugin
  • Delete key works correct in RED Brick plugin console tab
  • 4 weeks later...
